tuning turbo
Old Feb 26, 2007 | 03:40 PM
b18civ's Avatar
Default tuning turbo
Just wanted to know what you guys think. I'm gonna be installing a turbo kit on my b18c1 with forged internals, pistons at 9.8 comp., eagle rods. It's a turbonetics t3/t4 57 trim running at 8.7 psi. Other details Walbro 255lph fuel pump, rc 550 injectors, blox intake manifold, itr 2001 cams and springs. Do you guys think running a basemap made for the turbo setup on my p28 will be safe until I get some more cash to get it tuned? I understand I won't be at peak power until it is tuned, but as far as it being safe (ie. not blowing up the motor) keeping a/f ratios in a safe range. Can that be done with just a base map?
Old Feb 26, 2007 | 03:49 PM
itsslow's Avatar
I-VTEC, do you?
if you stay out of boost running a basemap will not hurt your car..
Old Feb 26, 2007 | 05:35 PM
Alpha's Avatar
Your best bet is to contact a tuner in the directory and setup an appointment with them
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Feb 26, 2007 | 08:39 PM
b18civ's Avatar
So pretty much everyone running a turbo in a honda has had to physically bring their car to a tuner , nobody has given specs of the engine to the tuner to have a chip made up and run off that? This must just go back to even though an engine can be the same no two engines will run the same principal?
Old Feb 26, 2007 | 08:41 PM
PooN_Lude's Avatar
A basemap is made to get your car from your house to a tuner, spend money on a tune the first time. It really isnt worth risking a motor
Old Feb 26, 2007 | 08:49 PM
Eluzzionz's Avatar
u dont need a more expensive dyno tune..gettin it street tuned should be fine for the time
Old Feb 26, 2007 | 09:03 PM
mtber's Avatar
+1
It amazes me how people spend a few thousand dollars building their motor & buying a turbo kit but they hesistate to spend several hundred dollars when its time to spend money on tuning.
Old Feb 26, 2007 | 09:07 PM
mtber's Avatar
This maybe the case if your tuner knows what he is doing.
A tuner maybe able to dial in your air/fuel ratios by street tuning your car, however ignition timing is a little different. Some local so called "tuners" think they can read a few articles on the internet & look at other people's basemaps to learn how much timing to run. This works for the most part, but do they really know what they are doing ?
This is where experience & the importance of a dyno comes into the picture.
Old Feb 26, 2007 | 09:10 PM
weeper's Avatar
if u aint boosten go home
Default get in tuned
mtber + 1 on tuning
Like us on facebook
Old Feb 26, 2007 | 09:13 PM
b18civ's Avatar
That's why I am here on TR askin, just weighin in my options, but thanks to all the nice people here on TR, it's getting straight.
