Tranny questions
Old Feb 6, 2007 | 07:46 PM
custom240sx's Avatar
DC Crew Member #1
Default Tranny questions
I have a B18a1 in my car with what I believe is a cable ls tranny...the code on the tranny (on the sticker next to the engine code on the block) is S1 1069151...can anyone tell me if this is the tranny I think it is and also, I heard that the LS tranny should be tached at like 3.5k at 80 while mine is at 4.1k at 80 mph with 205/50/15 tires. I was thinking about putting a GSR tranny in there. What improvement would I see in my quarter mile times and what would my rpm be around 80mph with that tranny? Thanks in advance.
Old Feb 6, 2007 | 08:48 PM
Eluzzionz's Avatar
the gsr cable is very very hard to come by...i also think u should go with a b16 cable tranny..it would be faster since its like the shortest geared cable tranny..and ur 80mph would be at 4750..but install a ls 5th and call it a day...atleast thats what imma do...
Old Feb 6, 2007 | 08:51 PM
DC Crew Member #1
well that was the point of the gsr so I can still keep the revs down somewhat. I wanted the added benefit of the 3rd-5th gear being just a little shorter than the ls so I would gain a little accel and sacrafice a little top end...by the way, with the b16 tranny, what is the mph when it is tached to 7k in 4th?
Old Feb 6, 2007 | 09:00 PM
Eluzzionz's Avatar
um...7k 4th..i think around 100or so..i think i was over 100 at 8200..i cant remember exactly my ignitor is messed up so my rpms have been jumpin around lately..and my mph is off by like 4-5mph at 30-50 from what ive seen..i wouldnt think they were off any more then that at 100..but never know?
Old Feb 6, 2007 | 09:32 PM
HondaHouse's Avatar
IS AT THE DEALERSHIP NOW
+1 gsr trans is not much longer or lower rpm than b16 trans...i know 70 mph with 205 50 15 in 5th gear is like 4300-4500 rpms...gsr would stick u at like 4100-4300.........go with a slightly larger (taller) tire to comsensate for rpm on highway...............or b16 with LS 5th gear
Mike @ 239-851-3234...anything pertaining to HONDAS
Originally Posted by Jordan T
sounds like you have a problem, your car is a mitsubishi, try replacing it.
Old Feb 6, 2007 | 10:04 PM
DC Crew Member #1
I just feel like it would suck because yeah I would be pulling through 1st 2nd 3rd 4th then pow it will feel like I hit sludge in the road if I had the LS 5th but I also know I don't wanna drive around town tached to almost 4k! My 4k is at 80mph right now...the reason I was asking what the b16 tranny in 4 gear at 7k rpm was in mph was because I know that right now I don't need to see 5th in the quarter and my top speed for my 4th gear at 7k is 106ish. I need to know if I will be seeing 5th with the b16 tranny in the quarter mile with a 7k shift point because if I do have to shift to 5th I will probably pull a slower quarter with the b16 tranny installed.
As for the tires...I just bought 205/50/15 Kumho Ecsta ASTs (all four) about a week ago so new tires are out of the question.
How much do you think a tranny with a b16 1st-2nd, GSR 3rd-4th, LS 5th would cost? I wish I could do b16 1st-3rd GSR 4th LS 5th but I think that this combination wouldn't be possible.
Old Feb 6, 2007 | 11:48 PM
Eluzzionz's Avatar
from what i found the b16 tranny with ls 5th is the only way ull have a decent 5th at 80..the gsr tranny shows actually the smallest 5th gear then the crx sir tranny then the xsi tranny..then ls..so what i would do is try to find a s1/j1 b16 cable and add a ls 5th..itll have the same 2.3.4 as gsr tranny...longer first then the gsr but shorter then the y1 b16..and obviously a ls5th...only thing "faster" would be the gsr trans all together but itll top out before the b16 trans would...so u could get a ys1 gsr and swap out ls 5th for an awesome set up as well
Old Feb 6, 2007 | 11:49 PM
Eluzzionz's Avatar
B-series gear ratios
Old Feb 7, 2007 | 10:41 AM
DC Crew Member #1
Now I have a lightweight flywheel in my tranny right now will that bolt up to the b16 tranny too? What improvement would I expect with that tranny verse the LS in a quarter mile run with the same motor...about .2 + or -?
Old Feb 7, 2007 | 10:44 AM
Eluzzionz's Avatar
prolly -.6 or better the ls tranny sucks so bad u dont even know...
