SVO blower question
Old Feb 6, 2007 | 06:56 AM
vortechstang's Avatar
Default SVO blower question
To make a long story short, I bought a 98 GT that had a broken timing chain. I replaced the chains, guides, tensioners, and the driver's side head, (pi swap already done). I got everything put back together and everything seems fine, idles fine and compression is 110 across the board. The problem I am having is as soon as I hit boost, the car falls on it's face. It is almost like someone is hitting the brakes. It has also backfired a couple of time when doing this. I am baffled on what could be the cause. The setup is this: completely forged bottom end (8.5:1), PI heads, stock PI cams, Mac long tubes, 42 lb injectors, SCT Xcal2.
Old Feb 6, 2007 | 06:16 PM
Zman's Avatar
I gota Cheby
are the pistons stock, I was under the impression on what i have read is when you go to pi heads on 96-98 your compression is over 10-1. Sounds like a fuel problem.
Only 1/4 mile track I know is Gandy Bridge
Old Feb 6, 2007 | 06:28 PM
Bottom end is completely forged and is about 8.5:1 cr. Yes, I agree, it sounds like fuel, but what would cause a too rich condition immediately upon the car seeing boost.
Old Feb 7, 2007 | 01:57 PM
99cobra281's Avatar
take it to race related
the COUPE that COULD
