need help anyone techs on board?
Old Feb 3, 2007 | 03:26 PM
C-Cali's Avatar
HP does not = IQ#
Default need help anyone techs on board?
as you guys may not know, my clutch went out on me so i had it replaced with a stage 2 gearforce clutch. it drove fine for about 2 weeks and it started to act up with wierd noises.
long story short
1. sit in seat, push clutch down. (feels hesitant and not smooth)
2. puts shifter into 1st gear (smooth)
3. releases clutch from floor slowly
.................. suddenly nothing happens!
car does not move at all.
4. press clutch again
5. put shifter back into neutral
6. without pressing the clutch i put the (shifter) into first (no grinding no noise smooth)
i have no idea what is wrong with my car
i put in a new clutch slave cylinder 2 hours ago
help please
the car is a 2000 3g eclipse with 103mi. 4g64 engine
Driver Swag > Driver mod
FabThis<---Click This
Old Feb 3, 2007 | 04:39 PM
2g's Avatar
2g
So said you put in a new clutch slave cylinder... did you bleed the clutch after install?
Who installed the clutch?
Old Feb 4, 2007 | 10:52 PM
C-Cali's Avatar
HP does not = IQ#
a buddy of mine installed the clutch he worked for a dealership so and he has changed them on the V6's.
i bleed the slave cylinder plenty of times for hours. so idk what it could be
Old Feb 5, 2007 | 10:09 AM
C-Cali's Avatar
HP does not = IQ#
Old Feb 5, 2007 | 10:15 AM
ON3GO's Avatar
External-Radiators.com
it sounds like its just not going into gear.
even if the shifter is put into gear doesnt mean its really in gear.
Originally Posted by Ronald Mcdonald
Your car is the epitome of all the is cool.
99' Golf more_door Canadian special
70' Bug
77' 280Z
76' 280Z
93' 240sx Sold
79' VW Rabbit "Bunny Luv" SOLD!
05' Scion xB SOLD!
88' VW GTI SOLD!
Only one in town where im blown via a dodge and squirted in a MEGA way....
Official TR SR20 Hater!!
Having more then 2 valves per cylinder is over-rated.
2V heads FTW! and Weight Reduction!
Old Feb 5, 2007 | 10:16 AM
BOX SENTRA's Avatar
OG MUDBONE 240sx
check your adjustment, when you put in a new master cyl, it usually needs an adjustment
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Feb 5, 2007 | 09:06 PM
C-Cali's Avatar
HP does not = IQ#
not master slave or now they are called clutch operating cylinder because the word (slave)....i swear.....ne ways thats what i replaced the clutch slave cylinder not the master
Old Feb 5, 2007 | 09:13 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
ohh ok
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Feb 5, 2007 | 09:22 PM
C-Cali's Avatar
HP does not = IQ#
damn this is all i get......maybe i should ask in a different forum. or thread section. so know one knows? well i'm going to see what i can do about getting it towed to my boy but thats 200+ just to tell me whats wrong with the tranny. ugh some bullshit
Old Feb 6, 2007 | 12:54 AM
AnthrAxNSB's Avatar
first
Do you have pedal pressure? I don't understand your description of the problem.
If you bled the system "for hours" and you can put the car in first gear without flooring the clutch pedal (while the car is running), and once in first gear, the car doesn't move, your clutch is not engaging. Drop your transmission. This is assuming it's actually going into first (check that your cables are working and that the lever is moving). Maybe you've lost first entirely. Try another gear.
