need info.....h22a stroker
Old Dec 6, 2006 | 01:29 PM
93civicgreasemonkey's Avatar
Default need info.....h22a stroker
i have a 94 prelude si with a 5th gen jdm h22a and i would like to know the best way to stroke the motor....ive heard many people tell me to mod a h23 crank but idk....all input is helpful, thanks....
Old Dec 6, 2006 | 02:24 PM
Blue92ludesi's Avatar
you can youse the h23 crank in the h22 block as long as the block has 50mm mains, the h22a1s and the h22as did, so your fine, the only problem is the h23 crank is cast, where as the h22 crank is forged. Also the h22 crank is balanced alot better then the 23 crank, so in order for you to rev the h23 crank out to 8 grand like you do the 22 your going to have to get the h23 crank balanced. I have built a H22 with a H23 block with H22 type s pistons, it ran awesome, but get soem forged pistons and forged rods to make sure nothing breaks in the bottom end.
other then that i thought crower made a stroker kit.
Honda of Wesley Chapel Crew Member #1
TR 5th Gen Civic CREW Member # 07
TR H2B crew #2
__________________________________________________ _________________________________________________
