want answers for turbo pistons
Old Dec 4, 2006 | 03:06 PM
LATINO HONDA's Avatar
BALLER
Default want answers for turbo pistons
cp piston
wiesco pistons
ariars pistons
nippon piston
wat do you think about wat set up i should do for my ls block b18a
i want to boost daily 6 to 8 psi and when i really want power i want to go up to 16 to 18 psi without hurting anything give me some info or your opinion thanks
Old Dec 4, 2006 | 03:14 PM
KJ's Avatar
KJ
bored at work
Wiseco pistons. I've used all of the above except for nippon which are not a boost app piston.
Old Dec 4, 2006 | 03:17 PM
DA92driver's Avatar
i was satisfied with my cp's , in my b18a. until the car got stolen
Old Dec 4, 2006 | 03:33 PM
BALLER
on ebay they sale nippon pistons that are turbo that has a low comp
and able to boost 18 psi
Old Dec 4, 2006 | 03:34 PM
Jap's Avatar
Jap
VTEC Out
I have always had good luck with CP and the older Wiseco
Hondata saves lives
Old Dec 4, 2006 | 05:08 PM
KJ's Avatar
KJ
bored at work
The nippons are still a cast piston, if you want to run a cast piston run your stock ones and buy a thick headgasket to lower compression.
Wiseco has the more advanced forgings of any off the shelf pistons available to Honda's. They come standard with a strutted skirt which reduces skirt area which in turn reduces friction, reduces weight (shorter wrist pin) and also come from the manufacturer with a coated skirt for break in. CP's have some very weak areas around intake valve reliefs on their 81.5mm pistons. Their 84mm pistons seem to be ok. Arias makes a very stout piston but it is rather heavy. In my personal motor I choose Wiseco over all others regardless of cost.
Old Dec 4, 2006 | 05:18 PM
B20.eg's Avatar
i have arias and they take what ever you throw at them. it makes me feel all safe and happy inside....I MEAN, I LIKE BOOBS AND BEER! HELL YEAH!
Old Dec 4, 2006 | 06:52 PM
weeper's Avatar
if u aint boosten go home
Default cp all the way
C.p. For 84mm Or 85mm Are Really Good For Boost !!!
Like us on facebook
