new problems.
Old Oct 31, 2006 | 03:51 PM
djlobes's Avatar
Im sofa king we todd did.
Default new problems.
here is the story. I bought a 93 si awhile back. The guy who owned the car used dot4 brake fluid for some odd reason. The guy that I bought the car off of was his friend and was selling it for him. He took some of the brake parts and swapped them with his civic for some reason. He did this before he knew the guy used dot4. So heres where im at now. I bleed the brakes pretty well, or at least what i think is pretty well but im still not getting any brake pressure.
Heres the way i bleed the brakes. I went in the order of passenger back wheel,driver front, driver back, passanger front. I poored dot 3 in the MC. I opened the bleed valve and pumped the pedal to try and get all the dot4 out of the lines. Then i closed the bleed valve and submerged the line in brake fluid. Then pressed and held the pedal. I opened the valve and waited untill the flow stopped. I did this on each wheel and still no pressure. I mean, that sounds like a pretty good bleed to me.
Im starting to wonder if some of the parts he swapped on arent good or arent compatible. my si's not abs right? i think only 94 and 95's where abs. The parts he put on came off a 4 door civic but i think there compatible right? any suggestions or ideas would be greatly appreciated.
Old Oct 31, 2006 | 05:03 PM
SmokinS13SR20's Avatar
That ginger...
Sounds like your Master cylinder is going bad man.
Old Oct 31, 2006 | 06:24 PM
djlobes's Avatar
mabey. I hate to buy more parts without knowing if it has something to do with the mixture of dot4 and dot3. Anybody know if a master cylinder from a 93 dx will work on the si? should right?
Old Nov 1, 2006 | 06:17 AM
skunk2racing97's Avatar
UF Mech/Aero Eng
i believe the Si master cylinders were always bigger than the regular models. (15/16" versus 13/16" i believe....) so no, you will want to go with the bigger Si model.
as for DOT4/3, they should be compatible with each other, so i wouldnt worry about that too much... if nothing else, the fluid will work as a test medium to find your other problems. once u get those straightened out, you can drop $10 and pump the whole system clean with some fresh DOT whatever you want.
Old Nov 1, 2006 | 10:32 AM
ekhatchboy's Avatar
Redrocket part 2
actually if dot3 and dot4 are mixed it will create a jelly like substance and clog the lines from what i was told from a brake shop before so i would recommend doing a lil more research before you buy new parts
Married to EkCoupegirl
Current Cars
05 ZX6R FOR SALE! Help me pay for school PM me for info.
95 Civic EX 4dr- D.D.
99 GMC Sierra 5.3l ext. cab. Under construction
05 Kawasaki Ninja ZX636R Plasma Blue
Old Nov 1, 2006 | 10:38 AM
B20.eg's Avatar
^most definatley the master cylinder. i had all the same issues and changed everything but the calipers and mc, and it came out to be the mc. it was like $70 with lifetime warrenty from discount.
Old Nov 1, 2006 | 10:47 AM
quickex99's Avatar
Scissor Me Timbers!
StopTech : Balanced Brake Upgrades .. hope this helps a little
Old Nov 1, 2006 | 11:29 AM
ekhatchboy's Avatar
Redrocket part 2
Hey that site actually gave me quite a bit of info. thanx for the link. rep for you!
Current Cars
Old Nov 1, 2006 | 12:07 PM
GradeA_TireFryer's Avatar
All American, rice eater!
The Differnce Between Do3 - Dot 4 Is Boiling Point Of The Fluid.
Mixing Them Together Should Not Make A Difference,
The Proper Way To Bleed / Change Brake Fluid Is Pass Rear - Driver Rear - Pass Front - Driver Front,
Look Under Your Dash - Pull Back The Carpet, Is It Wet? Find Where The Brake Pedal Connects To The Rod That Goes Thru The Firewall, Is It Wet There? If So Your Master Cylinder Is Bad!!!!!
Pirate Customs
Sound, Security & Style..... anything for your ride
Old Nov 1, 2006 | 12:16 PM
djlobes's Avatar
well as far as the order of bleeding i went by my haynes manual. And no the floor is not wet. I have an dx mc setting around that i might try and see if it works.
