Type r swap into a 93 del sol
Old Sep 19, 2006 | 06:47 AM
EG2DelSol's Avatar
Default Type r swap into a 93 del sol
i want to swap a b18c5 into my 93 del sol, but i am not sure about something....the car is already obd1, and i wanna keep it that way, and i was looking at the b18c5 motor and the 96-97 spec is 600 cheaper then the 98-00...now the question that i have is, what is the difference in the 2 motors? is one obd1 and the other obd2?idk...i have done research and cant find much of anything that i can use to distinguish the 2 motors....if anyone can please help me with info, it would be much appreciated..thx
FastAsLightning01
Old Sep 19, 2006 | 10:19 AM
integraman89's Avatar
lost u already???
i believe they are both the same obd, but as far as motor, i would say the fact that the 98-00 motors are newer and are an update of the older 96-97 model.
they probably built that motor and upgraded little things about it, or in another case the 96-97 is a way more common motor. so the less common one would be more expensive.
Old Sep 19, 2006 | 11:16 AM
mtber's Avatar
They are both obd2 motors.
One will have a better final drive in the tranny then the other (98+)
You will need to re-wire the distributor plugs to run the obd2 distributor on your car. Concerning your injectors & alternator, you can re-wire those also to run obd2 plugs or you can run obd1 bseries injectors/alt etc.
Concerning an ecu, get your ecu chipped for the new motor or buy a pre-chipped unit.
Old Sep 19, 2006 | 04:18 PM
BG-33P_Hatch's Avatar
Back in the Game
+1 to that......
R.I.P. Kevin Gonzales Aka Slo_Si
You will be missed by many.
R.I.P. Robert Kolp Aka 00ek
You will be missed brother
R.I.P Jake D Aka Cold_Beer
you will be missed brother
Old Sep 19, 2006 | 05:15 PM
The Spectacle's Avatar
Spent more money than you
one of the most notable differences between the two are the cams. 98+ make a bit more power.
Racing Integration
LHT Performance
My tuner is named Alpha
Old Sep 19, 2006 | 05:33 PM
mtber's Avatar
Barely anything IMO.
Old Sep 19, 2006 | 06:24 PM
lzylst's Avatar
intake cam has 3 degrees more duration on the 98+
96-97 gear box has a combination of itr/gsr gears and a viscous lsd .
Old Sep 19, 2006 | 09:33 PM
ragingdave's Avatar
MUSTANGandFORD TRDR DAVE
Good swap.
