Is 70mm T/B Too big?
Old Sep 18, 2006 | 07:06 PM
aznkhmerracernza's Avatar
Default Is 70mm T/B Too big?
Well I saw a 70mm T/B that i wanted for my LS/VTEC. It looks nice and fits my budget, but was told you don't want a big T/B. Here's the T/B. Just wanted to make sure before i get it.
USS MAINE BLUE CREW, BANGOR WASHINGTON!!
www.myspace.com/maknpanna
Old Sep 18, 2006 | 07:07 PM
integraman89's Avatar
lost u already???
depends on the setup
u really wouldnt need a bigger throttlebody unless you have ample enough upgrades that require more air intake.... like a turbo setup...etc
Old Sep 18, 2006 | 07:08 PM
chi town brat's Avatar
! Ne shab'rud'ni !
take the current one and have it bored out . max bore is very reputable.
Old Sep 18, 2006 | 07:09 PM
lost u already???
nice looking tb tho....
dont know about the color tho...
Old Sep 18, 2006 | 07:10 PM
lost u already???
also... buying a 70mm tb would be useless unless the intake manifold hole was bored to 70mm... if its a stock intake mani and a 70mm tb it wouldnt do anything because it still has to go through the smaller hole to the intake manifold
Old Sep 18, 2006 | 07:14 PM
I have a huge List of mods. Let me see if i can find an old post with the list.
Old Sep 18, 2006 | 07:18 PM
lost u already???
like i said before tho... if u have a 70mm tb... get ur intake mani opened up to 70mm or as close to 70mm possible without ruinin the intake mani
Old Sep 18, 2006 | 07:24 PM
Head work-
B16 Head, Skunk2 Valvetrain,Skunk2 STD Size Valves, KMS Silicon Bronze Valve Guides, AEBS IM, Hondata IM gasket, AEM Fuel Rail, RC 310 Injectors, B&M FPR, Port and Polish, 3 Angle Valve job, Buddy Club Spec 4's cams and camgears, OEM 3-Layer Head Gasket, and TODA Timing BELT.
Block-
B18A1, Shotpeened PR4 Rods, CTR 81mm Pistons, ACL Race Bearings and Thrust Washers, P30 OIL and Water Pump, ARP MAIN, ROD, AND Head Bolts.
Old Sep 18, 2006 | 07:25 PM
zcnitroso's Avatar
well, my personal opinion is turbo setup 70mm with edelbrok intake manifold, all motor 68mm with skunk2 intake manifold plus a upgrade injector, not that big 280cc or 300cc will be good. remember more air go in, more fuel you will need... that is my opinion...
I miss tampa fl
Old Sep 18, 2006 | 07:27 PM
zcnitroso's Avatar
oHH, never mind.. 68mm just find..
I miss tampa fl
