Another "DSM with a problem" thread
Old Sep 18, 2006 | 03:29 AM
DSMboost97's Avatar
How long will it last?
Default Another "DSM with a problem" thread
Well heres another problem for you guys, lately the car has not been running right. If im just cruising down the road and a light turns red and shift to neutral to come to a stop, the RPMs drop really low and it sounds like its only running on 2 or 3 cylinders. It will run like this until i come to a complete stop then the RPMs will start to pick back up again and it returns to a normal idle. If i just keep rolling, it will just keep idling very low for like 15 sec and then pick back up. If im just cruising in 5th gear at like 50mph, and step on the gas just a little it will hesitate and buck until it starts getting into boost range. (5th gear is the worst but it does it in all other gears too). Under boost the car runs fine, so i dont think it could be a boost leak. Starting to think maybe its a plug or plug wire, ill check the plugs today. Also my BOV dump tube ripped a few weeks ago and i taped it back together until i can find a new one, maybe its venting just enough to cause problems? Ill check that today as well. Anything like this ever happen to anybody else? Any help or suggestions? Thanks.
Old Sep 18, 2006 | 03:37 AM
mitsu420aT's Avatar
mine does the same ish and i have changed the plugs and wires. but i am venting.
Old Sep 18, 2006 | 04:03 AM
DSMboost97's Avatar
The fact that your venting is your problem. Get a recirc tube and it will run much better.
Old Sep 18, 2006 | 08:23 AM
Skyline Driver 5's Avatar
round and round it go
Its probably that dump tube but I bet if you change your spark plugs and maybe the wires you should have no more problems
TR "Old Skool EF" Member #150
Old Sep 18, 2006 | 11:21 AM
AnthrAxNSB's Avatar
first
What BOV are you using?
Old Sep 18, 2006 | 12:05 PM
mitsu420aT's Avatar
i am using the greddy rs , cant really rec.
Old Sep 18, 2006 | 01:58 PM
JR.'s Avatar
JR.
^ get a maf-t
98 talon awd automagic
Old Sep 18, 2006 | 02:12 PM
mitsu420aT's Avatar
more info please
Old Sep 18, 2006 | 02:25 PM
DSMboost97's Avatar
Im using a 1G BOV
They make a recirc kit for Greddy BOVs
eBay Motors: GREDDY Type RS BOV Recirculation Fitting FAST USPS SHIP (item 220028755153 end time Sep-20-06 01:46:02 PDT)
Old Sep 18, 2006 | 02:31 PM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
Originally Posted by mitsu420aT
more info please
maf-t= mass air flow translator.
which is a gm maf and a translator so you can run it on your car. basically youll be able to vent with it, and has alot more airflow potential then 2gmaf, not that theyre bad though.
SUCH IS THE RULE OF HONOUR.
