H23 Sleeve question
Old Sep 13, 2006 | 04:37 PM
LS4drCivic's Avatar
Is back in action!
Default H23 Sleeve question
Im very unfamiliar with H series, Im just wondering about the sleeves in a H23, i know its a closed dec kblock but ive been told the sleevs arent good for forged internals, just wondering if thats true and if so what id have to do to run forged internals on it.
Is finally 4dr pimpin again
Rollings not racing either go from a dig or go home
Old Sep 13, 2006 | 08:01 PM
warpd's Avatar
I think it is hard to find forged internals for it. The sleeves are made out of a different material that the B,D series engines. I am not %100 percent on that though I have never messed with one personally.
(813) 523-0168 Sid
(813) 476-5383 Justin
Old Sep 13, 2006 | 08:18 PM
Cold_Beer's Avatar
Rockin' 4 more Cylinders
h series sleeves are made from FRM material, and it eats up aftermarket pistons.
Mahle makes a piston that is compatable with it.
Stock H blocks hold alot of power, just the ring lands in the factory pistons dont hold up.
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old Sep 14, 2006 | 08:43 AM
KJ's Avatar
KJ
bored at work
There are failures with the Mahle stuff too because not many machine shops know how to hone the cylinders properly. I recommend to sleeve all h blocks, trying to save $900 for sleeving can cause you to lose a set of pistons and all the labor for another rebuild plus the cost of new sleeves on top of that.
Old Sep 14, 2006 | 11:07 AM
Xcalibur's Avatar
H22, H23 blocks(same block), have the FRM(Fiber Reinforced Metal) sleeves, as stated above. These sleeves are relatively thin, most people opt to cut these out and replace them with ductile iron sleeves, I wanna go the Mahle route, but only if I find a shop with a good reputation of doing this job successfully.
Xavier @ 813-368-4936
94 Accord EX H22/H23 Hybrid
Old Sep 14, 2006 | 02:20 PM
indeed's Avatar
tranny breaker
+1
Theres been this topic of discussion on Hondatech for sometime now. Some people have had good luck with the coated pistions, but in my experience they have failed. If you have an H22a1 block sleeving it is much cheaper because of the closed deck. Have a shop overbore it and press in straight sleeves. Deck it, then bore and hone for your new forged pistions. I've had this done in the past for $500-600 including the sleeves. Just dont try to ust too thick of sleeves or you will hit the waterjacket. Good luck with your build.
Jake
Old Sep 14, 2006 | 05:10 PM
LS4drCivic's Avatar
Is back in action!
thanks everyone, as many years as ive been in the honda game ive neevr ever touched a Hseries, ive been wanting to try somethign new so i figured a H series is the way to go, Ive got a friend whos big into H series and he uses Mahle pistons, hes had good luck with them never having one problem, Im just looking ot spray maybe a 75 shot on it but still be relaible, its all going to g oin a crx so i really wont have to do muc hto make it fast.
Old Sep 14, 2006 | 05:39 PM
indeed's Avatar
tranny breaker
Weclome to the big block honda world. H series in a rexy will get down, I really miss mine. Get a shorter final drive or look into the h2b conversion. Its deffinitely worth it.
Old Sep 14, 2006 | 06:26 PM
LS4drCivic's Avatar
Is back in action!
already tracked down the H2B kit, plan on running it with a Ys1 tranny with factory CTR LSD, just looking to have a nice little street car tha ti can put down fast track itmes and drive it home. Im looking into the H23 bottom end, 10:1 Mahle pistons, getting the roataing assembly balanced. so whats the deal with getting the hone right to make everything with the pistons go well?
Old Sep 15, 2006 | 08:06 AM
GradeA_TireFryer's Avatar
All American, rice eater!
special hone stone and they have to go real slow rpm when doing it -
united speed has a hone and has done a couple for us....
Pirate Customs
Sound, Security & Style..... anything for your ride
