wheel stud problems???
Old Sep 1, 2006 | 05:41 PM
jerry94civic's Avatar
Default wheel stud problems???
aight this mite sound stupid but im tryin to replace 2 of the 4 studs on my front wheel since they both broke. i need help. i got the rotor off and everything but cant bang the studs out cuz of the hub i think if thats rite . so i need help wat should i do from here. thanx for the input first time doin this so need help thanx.
Old Sep 1, 2006 | 05:54 PM
Help???????????????????
Old Sep 1, 2006 | 06:11 PM
cant somebody give me some info
Old Sep 1, 2006 | 07:52 PM
ttt please help
Old Sep 1, 2006 | 08:18 PM
warpd's Avatar
Honda-Tech.com: HOW TO: DIY Wheel stud replacement with pictorial
There is a write up for you. It is pretty straight foward. If you dont feel like waiting on people to answer your questions try out Honda-Tech.com: Main their search feature is awsome.
(813) 523-0168 Sid
(813) 476-5383 Justin
Cold_Beer's Avatar
Rockin' 4 more Cylinders
you need to have the hub pressed out, studs put in, then hub pressed back together w/ a new bearing....PM DEMONCIVIC he has a press and i belive he does that type of work.
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old Sep 1, 2006 | 08:20 PM
Cold_Beer's Avatar
or if you have a slide hammer, that works too
if you havent done it before i dont recommend it...even though i am a DIY guy...if you cang et your hands on a SLide hammer go for it.
_Jake D
Old Sep 2, 2006 | 07:35 AM
Pyroproblem's Avatar
Porsche Tech/Honda Tech
Or an air hammer with a punch set. I knock them back a little,cut off the head with a cutting wheel and the knock them back the other way with an air hammer and a punch set. Then just grind a flat spot on the new ones and drive the new ones in from the back...
Old Sep 2, 2006 | 07:36 AM
thanx guyz i just took it to a shop cuz it way to much things needed n its my daily driver to work. so thanx.
Old Sep 2, 2006 | 11:07 AM
Bseckel's Avatar
Honda certified
I would not recomend cutting a side off the stud. Just use the slide hammer and get the hub off replace the stud and then use the axle nut and a impact to get it back together. Thats what we do at work everytime we need to change the studs.
LOOK STOCK BUT GO LIKE HELL!!!!
