HELP! Whats wrong with my car now?
Old May 19, 2006 | 02:02 PM
DSMboost97's Avatar
How long will it last?
Default HELP! Whats wrong with my car now?
Well i changed the oil today, and when i was finished i fired up the car to let it ide for a bit and make sure nothing was leaking and everything was fine. So i got in the car, put it in reverse and started backing out like i always do. after about 10 feet or so of backing up, it starts running like shit. It barely holds idle and when i hold the revs around 2000, it misses and stutters a lot. It almost feels like a big vaccum leak but i checked everything adn nothing seems to be leaking. I pulled the plugs to see if maybe one or two of them had fouled but they all look good. Any ideas on what it could be?
Old May 19, 2006 | 04:19 PM
BoostLogik's Avatar
BoostAddict
I know this is a rather "basic" question, but how many quarts did you put in?
It does sound like something is fouled though or a sensor is shot. Nothing foreign happened to fall into the oil fill hole by any chance did it?
Old May 19, 2006 | 04:39 PM
DSMboost97's Avatar
I put in the 4.8 quarts or whatever the manual says, so its not low oil. and nothing fell into the oil fill hole. While the oil was draining, i put clamps on all the vaccum lines because with the new turbo, some of the lines were blowing off of the nipple at boost. I checked all the lines though and everything is still connected. I hope its nothing serious, the car is my DD.
Old May 19, 2006 | 05:34 PM
BoostLogik's Avatar
BoostAddict
Okay. So you did double check to make sure you didn't disconnect anything or anything is kinked?
I didn't so much think it was low oil, but possibly too much oil. You put the right amount in though, so you should be alright there.
You could try doing a leak test and compression test, to verify the cylinders are okay and none of them are having trouble firing. Alot of times, a very lumpy idle and bad performance through the RPM range usually leads to a cylinder being dead due to spark/fuel issues, or a valve being stuck open by a foreign object.
Does the car run like shit only at idle up to the 2,000 rpm range?
Old May 19, 2006 | 05:59 PM
DSMboost97's Avatar
Checked everything, nothing is disconnected or kinked.
Oil shouldnt be the problem, i changed it the exact same way as i always have with no problems.
I plan on doing a boost leak test before the weekend is over. What do i need to do a compression check?
im thinking its a spark or fuel problem but im no expert.
the car runs like shit all the time.
Old May 19, 2006 | 07:19 PM
bagabonesGSX's Avatar
If I put money on it I would say ignition system and most likely a plug wire fouled out.... Simple as that no need to go doing compression test or any of that shit..
Old May 19, 2006 | 07:40 PM
DSMboost97's Avatar
might try some new plugs first, if nothing after that, new wires. hopefully that fixes it. Any other ideas?
Old May 19, 2006 | 07:53 PM
Dick's Avatar
Hell on wheels
id go with bagabones.... your coil or a wire might be on the fritz...
Old May 19, 2006 | 09:01 PM
BoostLogik's Avatar
BoostAddict
Yeah. Always start with the cheapest possible solution and go from there. As you mentioned, try the plugs first. Then the wires next. It could be a bad plug and/or wire that's causing the car to run poorly/misfire.
Old May 19, 2006 | 09:19 PM
DSMboost97's Avatar
Would a bad plug/wire cause it to run bad all of a sudden like that or does it gradualy get worse?
