1995 Cobra for sale
Old May 11, 2006 | 09:37 AM
ODB's Avatar
ODB
S.Y.L.O.
Default 1995 Cobra for sale
Triple Black.....some decent mods...only 52k documented miles....some of you already know this car.....need to sell for a deposit on a new 06 GT. Car will be listed on ebay soon...I figured I would give you guys a crack.....car is in my gallery......
7300 firm......
Old May 11, 2006 | 11:14 AM
Shamus O'Toole's Avatar
Redneck Yatchclub member
Holy shit!!!!! Ican't believe your selling it. The 06 is nicw though!!! Call me you gaggot!
Old May 11, 2006 | 11:17 AM
MuTiLaToR's Avatar
Come Get Some!
Where is the car located and when can I come and look at it? Mods? Problems?
Originally Posted by ImprezvSE
It comes down to a safety issue...
If you can't bench press it, don't fuck it.
Other than that to each his or her own.
Old May 11, 2006 | 11:22 AM
ODB's Avatar
ODB
S.Y.L.O.
yup........can't believe it myself.....but I am going to buy a new one...I have the 90 coupe...so I can still build and blow up.....the 06 will be for the weekends only!
Old May 11, 2006 | 11:26 AM
ODB's Avatar
ODB
S.Y.L.O.
Car is in Tarpon Springs......you can see it anytime you want...but if you are serious make it happen right away...it will be listed on ebay..
the Bad....
A/C compressor blew out on me last year...I just replaced it and never recharged...the system doesn't have a leak...just need vaccum down and filled..
Could use new H pipe...was custom cut and welded in...
other than that it is perfect.....here are some more details....I will PM my cell number...
1995 Cobra 52k Documented miles on body
Car is called triple black. Black leather seats, carpet and dash. Car has 1998 tail lights installed with conversion harness. I still have the original tail lights.These were limited production for this year. There were only roughly 4,000 Cobra’s built in 1995.
SVT Build Certificate and Dyno Testing Documents in my possession.
CARFAX for this vehicle in my possession and available to new buyer...car has no negatives on the CARFAX. Everything checks 100%
Stock 302 rotating assembly
Edelbrock Performer Heads 1.94 intake 1.64 exh
Comp Cam Custom Grind with cam card spec’s
Scorpion 1.6 Rockers
1995 Cobra upper intake ported T/B opening
75 MM T/B
24 lb. injectors with cal MAF
255 walbro fuel pump
125 HP Nitrous wet Kit. Bottle bracket and warmer. Purge system installed.
Mallory Digital CD strike fire ignition w/ 2 step, rev limiter and nitrous window switch
MSD Billet Distributor
LT Headers w/ flowmaster series 40 cat back dumped
Dynoed @ Sam's before tune @ 371 Hp @ 4950 487 tq @ 3600
Suspension:
BBK upper and lower adjustable control arms
Eibach front and rear lowering springs. Drops car 2”
2001 OEM Cobra Rims w/ Faulken “Z” rated Tires with 90% tread
Car has a nice Alpine stereo with amplifiers and sub woofers
This car has a clean car fax and has never been repainted …..
Interior is mint and has very little wear on leather. All factory options work flawless ** EDIT...window motors need to have rubber bearings installed...I have new parts to go with the car...these door panels are easier to remove than fox door panels.... easy fix
New A/C compressor…(I have to charge)
Old May 11, 2006 | 11:36 AM
69Boss521's Avatar
PORK CHOP SAMICHES!!!!!
Bump for a great seller. I doubt you will have any problems selling the car man.
Old May 11, 2006 | 11:42 AM
ODB's Avatar
ODB
S.Y.L.O.
thanks man!...it really is a good car and has never given me any headaches.....the interior in this car is mint.
Old May 11, 2006 | 11:58 AM
TampaMille's Avatar
Resident Ham-N-Egger
Does a dark haired girl drive this car up I75? Saw a triple black Cobra with a 4sale sign on the back window. Rode next to her to try and get the number and info for it, but couldnt read a thing. Same car?
Old May 11, 2006 | 12:14 PM
79 pace car's Avatar
thinks TR sucks ass now
$300
just fucking with you Pat. good luck on the sale.
bump for a real nice car
this site sucks balls now. fuck tampa racing, not coming back.
Old May 11, 2006 | 12:38 PM
Not the same car!
