camaro front end help
a friend of mine has a '94. it's a 6cyl with 126k on it.
the problem is after about 25-30 minutes of driving the car starts to have a drag to it, like to the point where you don't need the brakes to come to a slow stop. also after 20-30 min of driving when the drag is occuring the car wont go over 60mph with out the front end shaking real bad. the drivers side front tire has a hot sort of smell and you could fry an egg on the rim it gets so hot. the front brakes are fairly new, any ideas? i was thinking some sort of bearing?
Originally posted by Vito_Corleone I'm a ricer.
thanks for the help, would the caliper sticking be a problem that would only occur after some driving? is this common in the camaros? i was thinking bearings only because it takes a little driving before the problems shows. i will have to smell it next time i see him to see if i smell brakes.
thanks again.
thanks again.
How is your braking? Does the car stutter to a stop? If you have a severely warped rotor, you could be heading up the brakes to the point of contracting. I mean, in a perfect world brake fluid doesn't expand with heat, but that car in its 10 years probably has some air and/or moisture in the lines. That'd cause the car to lock up after driving for a while.
Also, if the caliper bore is whack, using the brakes for 20-30 minutes'll heat it up enough to expand and then lock the piston in the bore.
Also, could just be a plain old wore out wheel bearing. Pull the tire off and look at it, if it's that bad, the bearing should be close to dust.
Edit - Regardless, replace the wheel bearing even if it is the brakes. Heating it up that much probably fucked it up.
