Hi question?
Old Mar 21, 2006 | 04:34 PM
Superkaioken's Avatar
Default Hi question?
hi this isnt jake this is his brother im having problems with my 92 nissan 240sx rear end.
you know the 4 bolts that hold rearend on whats the bushings called that go in there i will be driving down the road and the rearend of my 240 will be cockeyed littlerally driving sideways in a straight line at all times what is the solution to solve this problem?
Old Mar 21, 2006 | 04:38 PM
dan's Avatar
dan
Get the fuck off my lawn
i'd go get a 4 wheel alignment first, and if any of the subframe bushings or differential bushings are worn, they can inspect them and let you know.
if it's driving "sideways", look at all the rear arms going from the spindle (where the wheel mounts) to the subframe and make sure they aren't bent.
i know jake has a hicas, do you? if you have a hicas, the rear steering might be messed up, perhaps the tie rods are bent or the rack is locked up or something.
Old Mar 21, 2006 | 04:47 PM
no i dont have a hicas car it did have abs but that was disabled when the SR20 was put in the engine is fine runs perfect. but when i saw my car from behind when my brother was driving it. it looked dangerous cause his rear end was pointed to the right and front towards the left. litteraly it looked like this \ i know the front needs new rod bushings but the rearend is completely off. i know it will be a easy fix the prob is just finding out the source of the problems.
Old Mar 21, 2006 | 05:23 PM
steve's Avatar
madpom
get 4 wheel alignment if thats fine then you have a bent frame aka crab walking
Old Mar 21, 2006 | 05:44 PM
cool thanks for all the help guys i appreciate all the help.
