rims size options
Old Sep 7, 2005 | 02:31 PM
Philly Blunt's Avatar
TR Balla Donor Supreme
Default rims size options
as most of you know i am doing a widebody and paint and stuff so i need to rims as well the set i was looking at are 17x9 +32offset my question is how far will these stick out in the front with the sil front end and im getting the front fenders rolled and probably a 30mm spacer for the rear would theses fit ok? im only doing maybe a 3/4 inch fender roll
Old Sep 7, 2005 | 03:56 PM
maybe this will do better in drifting forum
Old Sep 8, 2005 | 10:19 PM
RubberBerner's Avatar
Sideways Maffia
depends how "widebody" you have... +32 offset is decent...but usually i see widebody 240sx's running more of a 17X9 +9 offset up front, thats using a 15mm pattern changer/spacer... Not sure if the +32 with the 30mm will cancel each other out...Matt could tell you everything about offsets, so could taylor...chime in guys.
NOBAMA!
Old Sep 9, 2005 | 03:39 AM
Chin's Avatar
MASTER BREWER:HOT TEA
17x9 will rub with anything higher than a 25 in the front. So I would recomend getting something with a lower offset if you are doing widebody. Stock fenders hold the A-TECH 17x9 17 offset in the front, so shoot for that goal. If you are hellbent on using the 32 offset you would have to get a 15mm spacer in the front, and then roll it slightly then it will look ok.
