Dualcam troubles
Old Aug 5, 2005 | 06:30 PM
asia989's Avatar
Why So Serious?
Default Dualcam troubles
I jus swapped a 93 dual cam into 89 sohc, my problem is the red dash lights dont light up at all when i go to start it, i tried push starting it and it tried to start any help would be great.
No Front Bumper Mafia crew#1 since 04'
The original 350Z Blue 240sx
Old Aug 5, 2005 | 06:54 PM
rasta's Avatar
Rasta Racing
Did you do the dash plug wiring properly?
Old Aug 5, 2005 | 06:57 PM
osama tim laden's Avatar
kings cannot fall.
either you didnt wire the dash wires correctly, or you have a bad ecu
Old Aug 5, 2005 | 07:26 PM
asia989's Avatar
Why So Serious?
well i didnt do the swap, wiring isnt my profession sadly, sean at CFP did the swap
Old Aug 6, 2005 | 09:05 AM
Epstein's Avatar
Retired
have you asked Sean about it? That seems like the logical thing to do.
Old Aug 6, 2005 | 09:20 AM
asia989's Avatar
Why So Serious?
Last time i asked him to fix something on this swap he said hell do it for a fee, after i had gotten the swap done, i swapped the starters out and still nothing , headlights dont dim when trying to start it.
Old Aug 6, 2005 | 09:23 AM
kings cannot fall.
whoaaaaa there. dont go bringing logic into this !
Old Aug 6, 2005 | 09:27 AM
kings cannot fall.
also, didnt you and your girlfriend complain about the job that was done on her car, and you went back?
either trust the shop, and let them fix it, or find a new place to do your work, i say.
Old Aug 6, 2005 | 01:28 PM
asia989's Avatar
Why So Serious?
i never went back after the swap was done, i talked to him about tosme other stuff about the swap like i said above.Im jus trying to figure out what else it could be.
Old Aug 7, 2005 | 12:27 PM
RubberBerner's Avatar
Sideways Maffia
has it ever worked since the swap? if you're not getting dash lights, there is a problem between the battery and the ignition switch. check your ignition/battery fuses, make sure they aren't blown. If it was your starter, the lights would come on and you'd turn the key and they'd go off (and come back on when you returned the key from crank to run). are you sure you have a good battery?
NOBAMA!
