Stuck with un tuned car..what to do?
Old Jul 30, 2005 | 06:36 AM
DrftDmn's Avatar
look ma , no hands!
Default Stuck with un tuned car..what to do?
This past Friday I had taken my car to XAT to get a SAFC II tune for my new setup
GT2871R
555cc Injectors
SAFC II
4 puck clutch
light weight flywheel
MR manifold and O2 housing....
When Martin opened the hood he said that the car should not e SAFC tuned in his professional opinion, Due to the S14 motor....He then Explained to me about a timing issue with the ECU and said I would need a Power FC or wait for the WC code ECU rom tune for S14! Now I just need to know what is better for my application, I found no comparison in the search. I just want to drive my poor car.
Top speed is nothing .... Acceleration , now thats a thrill!
Old Jul 30, 2005 | 07:07 AM
DrftDmn's Avatar
look ma , no hands!
Martin was good enough to mess with some of the settings while i was there and its a bit more drivable now...it was not a dyno tune, just took him like 2 minutes of tinkering with safc...i dont drive much....im going to drive my miata till i get the 240 figured out.
Old Jul 30, 2005 | 07:57 AM
Jeff240sx's Avatar
Cpt. Negative
Power FC is hot. But that doesn't matter.. you should have gotten a tune for even a low boost setup.
If I drove 2 hours to get something tuned, and didn't.. I'd be furious. KA-T owners have the same timing issue.. but that doesn't stop people from running 10+ psi on nothing but an s-afc.
Does your car at least drive normally after the "tinkering"? Like decent idle and a/fs?
Edit: I guess before jumping to conclusions.. did you tell them you had an s14 sr20det and 550cc injectors/2871r and wanted an afc tune?
-Jeff
** This space reserved for someone else's witty quote **
Old Jul 30, 2005 | 08:10 AM
DriftingDJ's Avatar
240LSX
you should have told them what setup you had when making the appointment... now you have a tough choice, I would get the power fc for now until you can get rom tuned.
Old Jul 30, 2005 | 09:52 AM
Sr20phantom's Avatar
RacingInnovations.net
I was thinking of doing a similar setup cept stock tranny components for now. But I have a SAFCII and I wanted a tune the difference for me is I have HKS 256I and 264E Step2 cams and I was looking to upgrade to a 2871R now if I get a tune with the stock t28 with a SAFCII would the same thing apply to me if upgraded turbos? Would I have to get a ROM Tune? Can you have a ROM Tune and a SAFC tune at the same tuime or do you eliminate the SAFC?
Old Jul 30, 2005 | 10:54 AM
DrftDmn's Avatar
look ma , no hands!
I spoke with Nick at XAT and he knew the setup I was running and Martin even asked him why didnt you tell me it was a S14 SR... Martin, said it would be a waste of money to have it tuned at that point. I wanted to speak with martin the 3 times I called but he was out doing house stuff i guess. The tinkering he did made it run a bit smoother but idle is still low.
Jeff I love you, be my babys dadda.....!Dave and Becky say hi
Old Jul 30, 2005 | 12:35 PM
chimmike's Avatar
They call me Harry
give Jim Wolf Tech a call...they might be able to help you, then you could use the SAFC to supplement the normally safe-rich tuning on the JWT ecus.
01 Sentra 1.8 turbo (sold)
91 Sentra SE-R turbo (sold)
03 350z turbo (RIP)
07 Mazdaspeed3
Old Jul 30, 2005 | 12:59 PM
Durdan's Avatar
No Ants Drift Member
FAIL
RIP Tim. i miss you, buddy
Old Jul 30, 2005 | 01:53 PM
Jeff240sx's Avatar
Cpt. Negative
Originally Posted by Taylor Durden
FAIL
+1.
