Worn or bad rings? What signs?
Old May 11, 2005 | 03:06 PM
SpottedMango's Avatar
Driven Concepts, Tampa FL
Default Worn or bad rings? What signs?
What are some typical signs of worn or bad piston rings?
Old May 11, 2005 | 04:14 PM
osama tim laden's Avatar
kings cannot fall.
smoking, loss of power.
do a compression check, and see if a cylinder is lower.
what is the problem?
Old May 11, 2005 | 06:28 PM
RubberBerner's Avatar
Sideways Maffia
put a little oil in the cylinder and if compression goes back up its rings
NOBAMA!
Old May 12, 2005 | 05:53 AM
Thanks guys.
The car, while idling is producing what seems to be white smoke. There's no smell of coolant and there's no mixture of oil and coolant.
We compression tested the motor and it was 160 across the board.
Any ideas?
Old May 12, 2005 | 06:06 AM
kings cannot fall.
if it only smokes when you roll into the throttle, its likely worn valve guide seals.
Old May 12, 2005 | 06:13 AM
No, it actually smokes while idling just from it sitting there.
Maybe a bad turbo seal?
Old May 12, 2005 | 06:17 AM
kings cannot fall.
good possibility.
Old May 12, 2005 | 06:19 AM
This is what I figure....
If it's the head gasket - There has to be smell of coolant in the fumes and if there's indeed a blown hg, then there should be some mixture of fluids.
If it's the rings, there has to be a cylinder that's low on compression.
Are those pretty good assumptions?
Old May 12, 2005 | 07:16 AM
kings cannot fall.
well, alot of times a blown headgasket wont mix fluids.
or at least not enough to see.
rings- there should be a low cylinder.
Old May 12, 2005 | 07:27 AM
Understand about the mixing of fluids on the hg. But the amount of smoking coming from the exhaust is pretty serious. Therefore, if the hg was blown, I'd think it be a serious hole.
Another observation I made was that if it's indeed the hg, then the coolant level should be low, or at least lower then what it was at. It's not, it's still topped of.
