91 eclipse gs-t conversion
Old Apr 29, 2005 | 09:55 AM
applesanyone's Avatar
Default 91 eclipse gs-t conversion
ok i bought a 91 eclipse. and my friend has a 91 gs-t that doesnt run. can i take the turbo and ecu and put it on my eclipse? and if so what else do i need to make it work?
Old Apr 29, 2005 | 11:22 AM
Shaun_GST's Avatar
<<<Tampa<<< >>>Bay>>>
your gonna have to buy a bunch of little shit to make it work. a lot of time and money. for a first gen, honestly, it would be better to just sell yours and buy a car that is already turbo. maybe even awd
Gripped XS | 18-55 IS | 50mm f/1.8 MK II | Sunpak 5000af
Old Apr 29, 2005 | 11:40 AM
Brandon's Avatar
Resident Dingo
+1
Old Apr 29, 2005 | 09:20 PM
Brandon's Avatar
Resident Dingo
Old Apr 29, 2005 | 10:07 PM
tsispyder97's Avatar
short answer yes you can
Long answer, But you haev to alot of changes to run even factory boost in your nt. Full turbo internal swap, cams, all the bolt on parts plus some, not worth it.
however instead of just saying no, or that its too hard, im goign to provide you with this link
http://www.angelfire.com/il2/freesty...onversion.html
you can decide for yourself
Old Apr 30, 2005 | 07:44 AM
dsmtuner's Avatar
gotta love the boost
cams off a turbo gen 1 and N/A gen 1 run the same part number......
Im working on the same project right now..... if you get the gs-t cheap enough it might be worth it. But most of the internals like spyder said will have to go, the heads are the same part number and so are the cams however... But time wise it will take you a long time.... just the wiring harness will take at least 1 full 24 hour day to run it through the car right.
SVT F150
Old Apr 30, 2005 | 10:33 AM
you right sorry, mixed up the 2.4 build im in the middle of when i was deployed. it was an auto head that he bought, had to switch in MT cams, then decided 264/272
425cicamaro
Drag Racing
43
May 5, 2005 11:25 AM
tman8621
Mar 17, 2004 10:29 AM
Chris LS
War Stories
13
Jan 25, 2003 03:22 PM
