need ignition help - eclipse
Old Feb 16, 2005 | 08:39 PM
russellbeermann's Avatar
F*ck da rent, get the Lex
Default need ignition help - eclipse
ok, here's my setup:
1g head on 2g block
1g coil pack
we rebuilt the engine and put it back in the car. but now we cannot figure out the firing order. the haynes manual (for both 1g and 2g) says the firing order for the spark plugs 4-1-2-3, but when we do this, the car runs like crap. we have tried just about every other variation, but nothing works properly. i know that the motor needs to be broken in and tuned for it to run properly, but we cannot get it to run smoothly. anyone have any ideas? is there something special i have to do with a 1g head/2g block setup? maybe one of you dsm experts can come out here and take a look at it. i would be willing to pay for your time and lunch or whatever. thanks
Russ
03 Infiniti G35
01 Lexus IS 300
99 Acura TL - for sale
96 Honda Civic DX - for sale
Old Feb 17, 2005 | 07:16 AM
dsmtuner's Avatar
gotta love the boost
did you check your timing and make sure you set it right, i also looked in my 1g book and it says the firing order is 1,3,4,2, so i think it should be the same for your car also double check your firing order.
SVT F150
Old Feb 17, 2005 | 07:24 AM
checked the timing. i will try that firing order and see what happens. thanks dsmtuner
Russ
03 Infiniti G35
01 Lexus IS 300
Old Feb 17, 2005 | 07:26 AM
dsmtuner's Avatar
ok let me know what happens, maybe i can think of something else if that dosent work.
SVT F150
Old Feb 17, 2005 | 07:27 AM
Ian MMF's Avatar
Omnipotence
4-1-2-3 sounds right to me. Check your base timing and make sure you have the right cylinders numbered.
Old Feb 17, 2005 | 08:00 AM
cylinders should go 1234 from drivers side to passenger side, right?
Russ
03 Infiniti G35
01 Lexus IS 300
Old Feb 17, 2005 | 08:04 AM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
yes, and it is a waste spark system so the firing order on the coil can be 1-4-2-3 or 4-1-3-2, also check your wires, and coil pack for spark
SUCH IS THE RULE OF HONOUR.
Old Feb 17, 2005 | 09:06 AM
getting spark on coil pack and wires.
Russ
03 Infiniti G35
01 Lexus IS 300
Old Feb 17, 2005 | 09:15 AM
BoosTb4BroaDs's Avatar
fix it?
Old Feb 17, 2005 | 09:25 AM
not yet...i'm actually at work right now but i'm trying to get some input from everyone so i can work on it tonight
Russ
03 Infiniti G35
01 Lexus IS 300
