Q45 Brake Qs
Old Dec 15, 2004 | 12:46 PM
PiNoYcLaSs's Avatar
Default Q45 Brake Qs
I want to do this conversion ASAP. Just want to make sure I got everything correct and i'm not missing anything. I have a 95 240 (5 lug) I can use a 95 Q45 caliper and rotor if im correct. From what I hear these two will just bolt on? Or do I need different bracket bolts or drill the holes larger? Do the stock brake lines work? I know I should get ss lines so does anyone know where to get them cheap? and if theres anything im missing please feel free to add. thanks!
Old Dec 15, 2004 | 03:28 PM
Epstein's Avatar
Retired
SPLparts has SS brake lines for $45 a pair. AFAIK, everything will bolt on to a 5-lug'd 240sx.
Old Dec 15, 2004 | 05:47 PM
hachibill's Avatar
yea sweet lemonade
ok , since your car is already 5 lug then it shoudl just be a bolt on affair. just be warned, there are 2 different size's of Q45 brakes. mine are off a 97 so i had to drill the bolt holes out in the spindle to make way for the bigger Q's bolts. but the pre 97 should be the smaller and use the stock s14 sized braket bolts. if these are the ones yo have then its all bolt up. the stock lines will work too. i just bought SS lines for my s13 and they work fine. i do need a z32 master though. too much front brake bias.
one more note, the pre 97 Q brakes will fit under 15inch wheels, but the 97 later will not!!!
Old Dec 15, 2004 | 07:11 PM
PiNoYcLaSs's Avatar
so I can just purchase a set of 4 ss lines for the stock 240 brake system since it'll also work for the front Q45 right? also the bolts that hold on the stock 240 brakes, will those work for the q45 calipers? or do i have to get the bolts for a q45 caliper?
Old Dec 16, 2004 | 07:27 AM
zenki_s14's Avatar
hey bill is your car 5 lug now or did you have your rotors drilled to fit four lug?
Old Dec 16, 2004 | 07:29 AM
osama tim laden's Avatar
kings cannot fall.
4 lug, redrilled rotors.
Old Dec 16, 2004 | 04:48 PM
hachibill's Avatar
yea sweet lemonade
yeah, 4lug with redrilled rotors. the stock lines off a 240 work.
