L98 Aluminum Corvette heads
Old Dec 12, 2004 | 07:19 PM
CamaroJoe's Avatar
Landscape Engineer
Default L98 Aluminum Corvette heads
Just looking for a ballpark dollar figure for how much these will go for at a junkyard. Also, what would I be paying for a good rebuild and port job?
-Joe
Old Dec 12, 2004 | 07:26 PM
myltwon's Avatar
Bolt-On 2v GT
depends where you go, miles on heads, amount of compenents on heads
could be anywhere from 50 - 300 bucks just depends who and where mainly
Old Dec 12, 2004 | 07:36 PM
CamaroJoe's Avatar
Landscape Engineer
I want valves and springs included, rebuildable condition. BTW, whats the max port size I can get on the stock valves?
-Joe
Old Dec 12, 2004 | 07:39 PM
myltwon's Avatar
Bolt-On 2v GT
I wouldn't want old springs and valves if it's been sitting
valve stuck open + piston upstroke = $$$$$
Old Dec 13, 2004 | 04:05 AM
CamaroJoe's Avatar
Landscape Engineer
I would imagine they would thoroughly clean and inspect both the valves and springs in the process of a head rebuild, leaving little chance they would still stick. I'll probably have them replaced anyway depending on what kind of port size is available and what kind of cam I get but I was mostly looking for pricing for now. If I can get a set for around $200, then thats not too shabby. What kind of availability do you guys think there will be on an item like this?
-Joe
Old Dec 13, 2004 | 05:13 AM
NXz28's Avatar
TR Balla Donor Supreme
For availability check local junk yards, and ebay. As far as a rebuild goes, the heads will need to be: cleaned, dissambled, valves checked, valve job, resurfaced, assembled, springs checked and shimmed for correct spring spressure. You will have to buy aftermarket springs if you run an aftermarket cam with more duration/lift. Expect to pay about $250-350 for machine shop fees depending on what you get done and where you go. Springs are about $100-150 extra. Valves cost $10-15 each extra. I'd say 2.00 or 2.02 valve are the bigger valves you can fit on those without having to install larger seats. Installing larger valve guides is about $15-20 per valve. Installing larger valve seats for bigger valves is usually $15-20 per valve.
Old Dec 13, 2004 | 09:30 AM
CamaroJoe's Avatar
Landscape Engineer
Ebay only has 1 set of these heads right now going and its for $395 starting bid. I guess theres a reason no one has bid yet. Thanks for the other info. Its exactly what I was looking for.
-Joe
