clutch problem
Old Nov 19, 2004 | 06:57 AM
88stang5.0's Avatar
00 Yzf R1
Default clutch problem
Got a 4000 mile FR king cobra clutch and it already worn out!! what could have caused this? the cable is as loose as it can be so it engages as much as possible but it only has 4000 miles on it wtf is this. there is also alot of clutch dust in the bell housing so i justy dont understand how it wore out so fast. any suggestions could it be a bad flywheel that is unsmooth or somthine causing it too wear out fast?
Old Nov 19, 2004 | 07:01 AM
shinysideup's Avatar
TR Balla Donor Supreme
are u saying it is in gear and wont move forward, or are you saying it wont let u shift properly?
Old Nov 19, 2004 | 09:50 AM
88stang5.0's Avatar
00 Yzf R1
no i didnt resurface the flywheel (stupid of me) and while i am driving in say third gear and step on it it revs up and i dont go anywhere unless i ease on the gas. then i can smell the clutch burning. it shifts fine its just either like completely worn or its for some reason no engaging all the way. but the clutch cable isnt loose at all, there is no slack in it.
Old Nov 19, 2004 | 10:04 AM
Steve B's Avatar
brings his heater.
thats why its broken aqlready, you only did half the job.
Old Nov 19, 2004 | 10:06 AM
88stang5.0's Avatar
00 Yzf R1
well that sux owell i know next time what to do. what clutch u guys recommend as a good clutch 2 use next time? thnx for the info
Old Nov 19, 2004 | 05:30 PM
Drewpw4ng's Avatar
stock :-\
im doin the clutch in my car soon. Im either gonna go with a spec 1 or 2. I have to look at the torque rating on them and if i eventually gonna go on the bottle. i think mars_302 said he has 50k on his spec 1 and hes layin down around 260 to the wheels.
Old Nov 19, 2004 | 06:35 PM
SoL_93GT's Avatar
Spec clutches are great, but you will definatley screw up your clutch if you don't resurface the flywheel.
Briane
Red 93 GT with only 9000 original miles on it.
HP Performance Stage 1 Street kit with 60mm turbo
Car Pics
11.29 @ 126 mph 16 psi
16 lbs of boost 509 rwhp/626 rwtq
12 lbs of boost 433 rwhp/571 rwtq
********STOCK MOTOR*******
Old Nov 19, 2004 | 07:30 PM
BDIX's Avatar
Dick is Huge!
spec clutches are good if your running a tremec, there notorious for destroying a T5
Totalled his shit!@
Old Nov 19, 2004 | 07:37 PM
TheShow50h's Avatar
The little 5.0 that could
King Cobra is probably the best choice for your car, but just get it installed properly and resurface the flywheel and you won't have any problems.
-Vince
