problem wit swap
Old Apr 17, 2004 | 02:17 PM
civicsk8er's Avatar
Got Midori??
Unhappy problem wit swap
I have a 96 civic hatch and i swapped a sir2 b16 into it. I wired everything and timed it. I also have no codes. My engine idles fine but when u try to rev it it just dies out at like 3500. It wont go pass 5000 rpms at all. Does anyone know what my problem is cuz it would really help me out.
thanks
Old Apr 18, 2004 | 02:23 AM
Drivermod03's Avatar
Mabey Throttle position sensor or injector bad
Old Apr 18, 2004 | 09:31 AM
SickOfAlltezzas's Avatar
ALUMINUM POLISHER
i believe he has the jdm b16 ecu that eh got with the swap
Originally Posted by 240Cyanide
TR's better anyways.. where else could you find all this variety of assholes, drug specialist, and pedo's? not on that gay dsm site!
Old Apr 18, 2004 | 11:37 AM
civicsk8er's Avatar
Got Midori??
its a p30
civicsk8er's Avatar
Got Midori??
wouldnt my check engine light be on if my tps was bad or damaged?
Old Apr 18, 2004 | 10:33 PM
crix's Avatar
:mugen member:
yes it will IF u jump the wires from the plug
IF U need help LMK..........
i can repair if your in tampa area
call or lmn........
Old Apr 19, 2004 | 10:48 AM
ALUMINUM POLISHER
call or lmn........
what do u mean if i jumped the wires from the plug?
Old Apr 19, 2004 | 12:57 PM
1fasthatch's Avatar
Traction Problems
The plug is on the bottom right side of you glove box you have to reach up and pull it down should be in a litle rubber holder thing but I wouldnt recommend doing it unless you know which plug is the right one.
www.artofspeedproductions.com
Old Apr 19, 2004 | 08:02 PM
civicsk8er's Avatar
Got Midori??
ok
