Porsche 356: Expert tips on maintenance, modifying and more
Old Nov 12, 2023 | 02:57 AM
Default Porsche 356: Expert tips on maintenance, modifying and more
by David S. Wallens
Nov 11, 2023 | Porsche, 356 | Posted in Buyer's Guides | From the Sept. 2016 issue | Never miss an article
Ah, the one that started it all: The 356 was Porsche’s first production automobile and the car that set the stage for the timeless 911.
For expert advice on this game-changing model, we turned to Chris Casler, sales manager of European Collectibles. The company has sold numerous Porsche 356s over the years and also has its own restoration shop.
Expert: Chris Casler
europeancollectibles.com
Many of the issues you see on these cars are related to the body. As with any 50-year-old car, rust is a common problem on a 356. Some of the most suspect areas are the floor pans, doors and battery box.
The lips around the inside of the doors and hood are an especially good indicator of how a particular car’s body has fared over the years. If there are bubbles–even slight bubbles–you could very well have a rust issue on your hands. If that lip feels smooth, almost like a ski slope, there’s a good chance that the car has seen Bondo in the past.
Water often leaks into the door itself and can cause rust problems in the bottom of the door–where very few people look.
It’s not uncommon for transmission synchros to go bad. From 1956 on, these cars came with a full-synchro gearbox. If there’s grinding on downshifts, it may be a sign that the transmission needs to be removed and refreshed with new synchros and bearings.
If the car has been sitting for a few years, almost everything in the brake system should be replaced: master cylinder, slave cylinder, hoses, etc.
These cars came with very precise steering from the factory. If there’s much play in the steering, the steering box needs to be replaced or rebuilt. If the worm gear is worn down–not terribly uncommon– your only choice is to replace the whole unit.
Working on the suspension will give you the most reward for your money. There are three main options when it comes to shocks. If you want to maintain the OEM performance and feel, go with Boge units. If you want a stiffer, sportier feel, install the available Bilsteins. And last but not least, if you want a fully adjustable experience, Konis are a good way to go.
While you’re in the area, double-check the date codes on your tires. These cars don’t usually see too many miles, so you may find old rubber that shouldn’t be on the road anymore.
As far as power goes, a 356’s potential is fairly handcuffed by which engine it starts out with. These cars came in many different trims with many different-sized engines. If you start out with one of the smaller engines–65 horsepower stock–you can’t add too much power before you start to see overheating issues. The smaller engines were built with smaller oil journals, so they don’t handle the extra heat very well.
Speaking of overheating, it’s a good idea to add a tall fourth gear if you ever have the transmission open for a rebuild. At 80 mph, a short fourth can drop your revs 750 rpm.
If you don’t have a taller fourth gear, don’t push your car hard in heat or up hills at speed. That’s just asking for some catastrophic engine damage. If you see temps climb while driving on a hot day, slow down 10 mph to lower the rpm. The temperature should drop within 5 minutes.
Another good upgrade to consider is a short-shift kit. You can find them for about $500, and they improve the drivability of the car.
These engines burn about 1 quart of oil every 1000 miles. Remember to check the oil regularly. If you can see the level on the dipstick, you’re within half a quart of the ideal level–these engines only hold a little over 4 quarts of oil. If the oil level is lower than the dipstick’s reach, add a half-quart at a time and recheck until you’re in the correct range. Overfilling oil will cause the car to smoke. If you’re traveling, always remember to bring a quart of oil with you.
If you’re shopping for a 356, you should absolutely bring any prospective purchases to a Porsche 356 expert. They will be able to spot the good and bad better than even your best non-Porsche mechanic. Roughly 50 percent of the cars we look at have been in an accident in the past.
Bottom line: Buying a good car will always be less expensive than taking on a project. If you aren’t going to complete a concours-level restoration, it really isn’t worth it. And a good restoration can easily turn into a six-digit expense.
Old Nov 12, 2023 | 02:58 AM
May 19, 2016 12:42 AM
Sep 25, 2014 01:00 PM
subbie racer
Nissan/Infiniti Tech
Aug 24, 2010 05:50 PM
CoRDiTe
Dec 22, 2009 05:14 PM
THE_ONE
Apr 27, 2006 09:04 PM
