HELP PLS! 2001 vw Passat
Old Sep 13, 2010 | 02:16 PM
Lateniteracing54's Avatar
Default HELP PLS! 2001 vw Passat
My buddy has a 2001 vw passat V6 30v its been over heating if u run the car for one min. waters stays full if u run it for 3to 5 mins and shut it off the min the motor shuts off the coolent res gose empty and a little pump or something on the passanger side of the car, is still running we can hear water but no leak just water flowing through the hoses and then u star the car and still empty didnt leave the car ruuning just stared it for a sec to see if the water returned. check the oil to see if the water was flow in the the oil pan but not milky or water in the oil i lost help pls
Old Sep 13, 2010 | 06:35 PM
DubDaze's Avatar
VeeDubin It
Is the heater core leaking on the inside of the car?
Old Sep 13, 2010 | 07:31 PM
VR6exxy's Avatar
fixed it for people that can't read idiot.....
Originally Posted by Lateniteracing54
My buddy has a 2001 vw passat V6 30v and the problem is its been over heating. If you run the car for one min. water stays full. If you run it for 3 to 5 mins then shut the motor off the coolent res. goes empty and a little pump or something on the passanger side of the car continues running. We can hear water flowing through the hoses but can't find any leaks. Then when you start the car the res. is still empty. We didnt leave the car ruuning just started it for a sec to see if the water returned. Check the oil to see if their is water was in the pan, but the oil is not milky and no water was in the oil. I'm lost, help pls
I love turtles
Old Sep 14, 2010 | 06:48 AM
thanks dub ill take a look at it, thanks again! if there is any other things u can think of pls lmk
Old Sep 15, 2010 | 07:58 AM
not the heater core thanks alot dub ill keep tryn to find it if anyone has any ideas im open for anything right now lmk thanks again
Old Sep 15, 2010 | 12:37 PM
DubDaze's Avatar
VeeDubin It
I think you need to Vac down the coolant system and refill it properly
Old Sep 18, 2010 | 10:05 AM
ok thanks dub last thing im gonna try then he can take this vw to the shop thanks
Old Sep 18, 2010 | 02:50 PM
DubDaze's Avatar
VeeDubin It
Take it to me.
