how to install boost gauge
Old Oct 28, 2007 | 11:29 AM
GsT Racer's Avatar
back in a 4g63
Default how to install boost gauge
on an 07 passat 2.0t, what vaccuum source should you tap in to?
Old Oct 28, 2007 | 02:21 PM
DubDaze's Avatar
VeeDubin It
Fuel pressure regulator, anything coming off the intake manifold or from the turbo charge pipe.
Old Oct 29, 2007 | 03:53 AM
Caan's Avatar
raising the standard
Anywhere after the throttle body. It will not read vacuum on a charge pipe nor should you tap from an FPR. Any deviation in a vac/boost signal could yield changes in AFR. Also, the 2.0t's FPR is electronic due to the high fuel pressure...
Mk2 vr6t chirpin' sixth...
Old Nov 1, 2007 | 02:33 PM
hmaudisport's Avatar
"Euro Kidz"
hahaha passats!!!
"im always on topic..... dont delete me. dont hate"
The originator of the 9". ask daredevil not jdmgeorge
