Anyone want to help me...
Old Jun 20, 2007 | 10:44 AM
moscowdog's Avatar
Default Anyone want to help me...
I've had this 16v swap into an 84 rabbit for a year now... Kind of dead in the water. Does anyone know someone (or themselves) that is expierienced with this swap? Want to get this goin!
Old Jun 20, 2007 | 11:01 AM
Green_Lantern's Avatar
Green Lantern Corps
Where exactly are you in the swap...
If you're not cracking oil pans your not low
Old Jun 20, 2007 | 12:29 PM
jgti1's Avatar
AKA: jgti
What do you have left on the swap? If you use the ECU, and wiring that came with the motor, than it should pretty much should be a straight forward swap.
Checkout this search on 16v rabbits.
VWvortex Forums: Search
DA BUCKET
<a href=http://i84.photobucket.com/albums/k22/jgti/100_3052-2.jpg target=_blank rel=noopener noreferrer nofollow external target=http://i84.photobucket.com/albums/k2...100_3052-2.jpg" border="0" />
Old Jun 20, 2007 | 05:27 PM
moscowdog's Avatar
I mean Im far in the swap... to a point where I just don't know what the wiring needs done... and a few mod's that I don't know about. The engine is in, all wiring is "in" just sort of a mess... airbox needs mod'd and put in along with the downpipe and all my cooling setup...
Old Jun 20, 2007 | 05:51 PM
jgti1's Avatar
AKA: jgti
Sorry man that thread I posted eariler expired.
Check this one out. All the info on the 16v MK1 swap, plus many people that have done the swap to get answers from.
VWvortex Forums: The Official A1 16V post.
DA BUCKET
Old Jun 20, 2007 | 07:43 PM
Green Lantern Corps
Wiring is always a pain! That why when i pull something apart i label it. But when you say you have the wiring "in" do you mean everything is connected or you have the wiring in place and your confused to where it goes... And where are you located cuz it would be a lot understand in person...
Old Jun 21, 2007 | 05:59 AM
moscowdog's Avatar
Everything is essentially connected... the main problem is the two different style of fuses. I.e Old 84 wiring harness uses an individual pin for each wire, hard wired into the back of the fuse box, and the "newer" 89 jetta harness of using with the 16v has the pins going into switches, which then go into the back of the fuse panel... So right now I have both fuse boxes...
I am in Lakeland.
I've been posting at vwvortex for along time now, what I think I need is some practical help from someone who has done this before hands on... I know it won't take much to get this thing going, no more than 1-2 days tops.
Old Jun 21, 2007 | 07:02 AM
Green Lantern Corps
I am in Lakeland.
Let me talk to one of my friends... Hes got great knowledge about rabbits so i'm sure he can give you a hand in solving your problems. His name on here is On3Go. But ill see him tonight at the VW meet so ill bring it up to him...
Old Jun 21, 2007 | 06:00 PM
moscowdog's Avatar
That'd be awesome... I've done everything solo so far, that can be fun if you know what you're doin, but in my case...
