Cooling problem on a MKIII Jetta
Old Jul 24, 2006 | 01:35 PM
Josh.'s Avatar
The Integra Guru!
Default Cooling problem on a MKIII Jetta
It runs fine than about 5 minutes into the drive it overheats?
Anthing any one can think of that will make this do it..
We put antifreeze in it and still didnt work, and than WATERWETTER, still nothing.
-Josh
04' Crystal White Lexus IS300
04' Premium White Pearl RSX-S
Originally Posted by 94lsteg
Old Jul 24, 2006 | 01:39 PM
mrnicejetta's Avatar
farfromügen
Does the radiator fan come on? If the fan doesn't come on hook up a battery to it. If it still doesn't come on you need a new fan motor. If it did come on with the battery then you need a new switch/relay.
If the fan comes on when it is supposed to then check the thermostat. It might be stuck closed or doesn't fully open. If the thermostat is fine then it looks like a water pump.
Der schnellste mann im langsamsten auto
Old Jul 24, 2006 | 01:41 PM
Josh.'s Avatar
The Integra Guru!
where is the Thermostat?
it's a 2.0
Old Jul 24, 2006 | 01:42 PM
farfromügen
I know on my 16v it is where the lower radiator hose attaches to the water pump. I think it's the same on the 2.slow, but don't hold me to it.
Old Jul 24, 2006 | 01:47 PM
Josh.'s Avatar
The Integra Guru!
This is why i stick to my Honda and gave my brother the Jetta
thanks man
Old Jul 24, 2006 | 01:54 PM
farfromügen
No problem. Hope that helps.
Old Jul 24, 2006 | 03:00 PM
Caan's Avatar
raising the standard
ya, its under the a/c compressor.
Mk2 vr6t chirpin' sixth...
Old Jul 24, 2006 | 03:18 PM
BisquitMan's Avatar
Salad Tosser
I am guessing it wouldn't be the radiator fan if it overheats while driving. The airflow from driving should be enough to keep the car cool.
Old Jul 24, 2006 | 04:47 PM
euro4-door's Avatar
could be the wrong coolant your putting in..needs to be phosphate free..just a possibilty
Old Jul 24, 2006 | 04:56 PM
das_uber_hase's Avatar
if it's not caused by what's mentioned, it could be plugged from mineral deposits. i've had two dubs that overheated due to it. a lubro moly flush with a refill of distilled water and g12 solved the problem on one. the other had to have the radiator replaced from buildup. from experience, waterwetter always left a chalky film. i think it's mainly meant to be used with straight water with religious intervals.
