anyone have a solid mount?
Old Apr 8, 2006 | 08:05 AM
bcarter82's Avatar
Harbor Rat
Default anyone have a solid mount?
i have a mk2 jetta and was thinking about buying a solid front mount,just wondering if anyone has had one?and what do you sugest for plugs and wires
thanx dave
It does what its told!....it puts the lotion on the skin!
Old Apr 8, 2006 | 10:21 AM
mrnicejetta's Avatar
farfromügen
I have a BBM solid mount and VF engineering tranny mount. I personally love both of em. I hate the oem hydro mount, I got tired of replacing them so I went with the solid. Keep in mind you will feel a LOT more vibration in the cabin. On the plus side my girlfriend now likes riding shotgun more. For plugs I like the NGK iridiums and for wires I have the Autotech 10.4mm.
Der schnellste mann im langsamsten auto
Old Apr 8, 2006 | 10:25 AM
farfromügen
One thing I should add about the BBM mount...There are three bolts that thread into it. One on top for the bracket, and two on the bottom for the cross member. The main lower bolt they provided for the crossmember was too short(total length of 40mm, if memory serves). It wasn't long enough and ended up stripping the first 2 threads in the mount. So I went to Advance to get a 50mm bolt. Problem solved, and I love it.
Old Apr 11, 2006 | 11:11 AM
farfromügen
Yeah, well, um, I hope that helps.
Old May 3, 2006 | 07:51 PM
AlexCoppas's Avatar
Post Well... its really cool!
Heh..Where is here some web gallery about site creators?I'm need it.For example, as here - Google, I'm really have seen ithere.Good luck!
Old May 4, 2006 | 02:24 PM
BisquitMan's Avatar
Salad Tosser
Make you own. I made one for a friend when he broke stock mounts twice in two weeks. I had a block of polyurethane laying around, so we cut off a piece and drilled a hole for the middle bolt. It worked great.
Old May 4, 2006 | 04:28 PM
zymol's Avatar
Driver
I have a hybrid mount that is my own creation. You should try it. Here it is.
Start w/ harder durometer rubber motorsports mount and short length of seatbelt from dead car. (black color obviously) cut one slit in seatbelt long enough to pull open and poke bottom stud of mount through. Compress mount w/ v-forked c-clamp to allow the belt to be wrapped around the mount w/ minimal slack. Mark it, and cut similar slit as before. hook over top stud of mount, and release c-clamp. Voila!! you have a mount that will not stretch beyond tension of belt but will still provide damping of factory motorsport mount. (women won't call it a piece of ish rattle trap anymore.)
Old Jun 24, 2006 | 01:04 AM
ManForse's Avatar
Post Somesing for you
he I lovelove you all!
