question
Old Jun 19, 2005 | 08:16 PM
SkwervE's Avatar
realer than most
Question question
how can i disable the daytime driving lights?
Old Jun 20, 2005 | 03:04 AM
BisquitMan's Avatar
Salad Tosser
Pull out the light switch. Disconnect the wire for the DRL's, bend the tip, and wrap a piece of electrical tape around it.
Old Jun 20, 2005 | 08:50 AM
SkwervE's Avatar
realer than most
how does the switch come out..i dont want to break it
Old Jun 20, 2005 | 11:05 AM
3liter914-6's Avatar
You can also just pull the relay under the dash. Should be marked "173" on the relay. Position 7 or 8 I think . I prefer this over the more destructive switch method. Only drawback is that your parking brake warning light won't work any more. Wouldn't bother me, but for some it might. You can probably make a jumper that'll reactivate the e-brake warning if it concerns you.
Good luck.
Old Jun 20, 2005 | 12:09 PM
SkwervE's Avatar
realer than most
thanks i think i will try the relay first before i start pullin stuff out..
Old Jun 20, 2005 | 12:27 PM
SkwervE's Avatar
realer than most
i couldnt find the relay..is it under driver side dash? or passenger?
Old Jun 20, 2005 | 01:26 PM
galista's Avatar
Default drl
the easiest way is to pull out your switch by pushing it down and turning it as if you were turning on your headlights. disconnect the harness from the switch and in the switch there are some pins look for the pin that says TFL and wrap a piece of tape around it and plug it back in and then you would have disconnected your drls
Old Jun 20, 2005 | 01:38 PM
SkwervE's Avatar
realer than most
ok i got it out and got the harness disconnected but i dont see TFL..what color is the wire?
Old Jun 20, 2005 | 02:38 PM
SkwervE's Avatar
realer than most
i found the tab and i just bent it down..thanks
