99 passat turbo?????Need Help???????
Old May 26, 2005 | 04:37 AM
sireal's Avatar
Shooting For 14's
Default 99 passat turbo?????Need Help???????
Ok I tried to do a favor for a friend, with no luck. He took his passat to the dealer and they said he needed a new turbo and cat. I changed the turbo and gutted the cat (he is on a fixed income) when I start it up now its alot better than before but when you put it in gear it has no power, it takes almost a full minute to hit 60......Before it wouldnt run for more than a second or two
If anyone has any suggestions or would like to make some extra cash to come fix the thing, let me know.
Thanks in advance.
Old May 26, 2005 | 05:36 AM
03gti1.8t's Avatar
got torque?
first, i would get the car scanned for codes. go to autozone and they will scan the car for free. that will atleast give you an idea of where to start. then i would double check all what you have done. does he have a boost gauge. look for signs of any leaks.
[+]H&R cup kit[+]Neuspeed sways and front tie bar[+]Forge 007p[+]3" Forced-Motion turbo-back[+]Injen CAI[+]ECS Dog Bone mounts and STG 1 clutch/flywheel kit[+]Audi TT short shifter[+]REVO 4bar cai & turbo-back file w/ sps 3[+]SAMCO TIP[+]NGK Bk7eix[+]17" RS 4 Replicas[+]VDO[+]42DD A-pillar pod and clear corners[+]
anyone need gmail invites? pm me.
Old May 26, 2005 | 09:59 AM
sireal's Avatar
Shooting For 14's
No boost guage I might pull mine off my car to check it out. Will pull codes tonight.
Thank for the suggestion.
Old May 26, 2005 | 03:42 PM
sireal's Avatar
Shooting For 14's
Old May 31, 2005 | 11:48 AM
BucWildBob's Avatar
check timing belt.. how many miles. any audible leaks vacuume or boost. is it running on all of the cylinders. is the mass air flow plugged in correctly. was anythign done to the car before the problem happend?
Old May 31, 2005 | 01:48 PM
Subsonic's Avatar
don't be bullshittin!!!!
check the codes and reset them and see what comes back.... Im assuming this is an automatic and the check engine light is on.... if this is the case then it is still in limp mode and wont come out until the ecu is reset....if not the case bring the car back to the dealer
hope this helps
Got a VW? Hit me up!
M.E.C.P. certified custom stereo builder for hire
This Space for Rent
Old May 31, 2005 | 04:26 PM
sireal's Avatar
Shooting For 14's
160,000 miles car ran great one day and like crap the next. nobody has done anything to it except the dealer to give an estimate. mass air flow is plugged in correctly. I was thinking timing might have jumped a tooth, but have not looked yet.
How do I reset the codes????
