engine swapping
I would check to see if either engine was an option in the other vehicle.
A lot of Ford transmissions have the same bolt pattern and except for the gear ratios, they will interchange.
Another way is to go to a junk yard and ask if they will print out an interchange for each of the year cars and which transmissions will fit.
I sometimes do this at LKQ in the Tampa Bay area.
On the subject of gear ratios, sometimes the interchange will not show a swap (even though the bolt pattern is the same)
because the gear ratios are not precisely identical.....sometimes no big deal because the engine revs slightly higher or lower.
A transmission shop might be a good place to check for interchangeability, also.
If you get an answer, offer the guy a $5 bill toward their coffee fund.
American Iron Tech
03-21-2020 06:50 AM
American Iron Tech
12-16-2019 04:21 PM
limegreenneon
The Ford Forum Lounge
4
10-26-2009 07:42 AM
