Front End Shaking, Question...
Old Apr 26, 2009 | 12:35 PM
I-NEED-VTEC's Avatar
I have NO vtec!!!
Question Front End Shaking, Question...
Ok, I have a 97 Dodge Ram 1500...I replaced the brakes on the Passenger side, but not the Drivers side(they weren't as bad as the Pass. side)...It just started to shake when taking off and coming to a stop...I'm gonna be putting the Drivers side brakes on Tomorrow but my Question is
Are the Rotors causing the shaking?...I'm pretty sure it is but wanted to be Positive before I just put the new brakes on and not get the Rotors Resurfaced...Or is it because the Pass. Side had Alot more brake then the Drivers side?...
Any Ideas?...
Fighting for peace is like
screwing for virginity.
TR "Old Skool EF" Member #097
http://www.myspace.com/keith1201
Old Apr 26, 2009 | 03:58 PM
Country Boy's Avatar
can survive...
Does it shake only when the brakes applied? It could also be worn ball joints, tie rod ends, bearings... Rotors and brakes usually only cause a shake when braking.
Old Apr 26, 2009 | 04:01 PM
EfWorld's Avatar
you put the wheel back on right?......
is this under brakeing or just driving?
TR "Old Skool EF" Member #48
99 Mitsu Eclipse GS-T DD
91 Honda CRX Si
91 Honda Civic Si
91 Honda CIVIC Si FOR SALE da front brakes. mint interior, 650 buks
Old May 15, 2009 | 01:08 PM
Southern_SS's Avatar
first thing i would do is get the other side done also. never only do one side and not the other. when you jack it up see if there is any play in the tire. grab it on opposite sides and shake it if there is excessive play you may want to replace the hub bearings. and also after jacking up the front end make sure you drive in reverse for about 20 feet.
