f150 I6 ?
Old Apr 22, 2008 | 08:15 PM
Hellaslow's Avatar
...TR's resident Racist..
Default f150 I6 ?
will a I6 be able to tow 5-6k without strain?
i'm talking about city and highway speeds?
i need a rig to tow my yota to the mudhole and back without problems...
A clever person solves problems but a Wise person avoids them... A.Einstein
Old Apr 24, 2008 | 10:35 AM
TBSpyder's Avatar
I would think you'll be fine. Might want to think twice about taking it cross country...but to the mudhole and back I wouldn't worry about it.
Old Apr 24, 2008 | 10:52 AM
coolcloo1019's Avatar
Uhhh...
I don't think it's a question of "can you tow it", it's more of a question, can you stop it?
Tennessee Vols
Old Apr 27, 2008 | 07:07 PM
Hellaslow's Avatar
ok so will a I6 f150 stop 5-6k?
or
will a I6 f250 stop 5-6k?
Old Apr 27, 2008 | 07:19 PM
jriggs's Avatar
is better than you™
never seen a 250 with a 6 banger. i think an 150 is rated near that towing weight (i might be super wrong)
what year is the truck in question?
Old Apr 27, 2008 | 07:23 PM
Hellaslow's Avatar
96 was the last year the I6 came in the 150 and i'm not sure what year they stoped with the 250.... my father had a 80's 250 with a I6...
the reason i kinda wanna stay with a I6:
1.gas prices
2.I6's are work horses
3.gas prices
Old Apr 27, 2008 | 07:48 PM
IwinUlose's Avatar
is breaking shit
with a frame mounted hitch it wont be a issue. if its a bumper mounted ball dont even attempt it.
Originally Posted by killerMikeD
What kinda pussy needs sprockets to do a wheelie anyways?
Originally Posted by 95coBraSVT
I think I still take the "stupid owner" of the month award here.
RIP Tad.
Old Apr 27, 2008 | 08:20 PM
jriggs's Avatar
is better than you™
96 should be good for around 7500lbs with a frame mounted hitch according to the spec sheet
Old Apr 27, 2008 | 09:08 PM
Hellaslow's Avatar
i think it will work....
based of a 1993
Fuel Economy (city / hwy): Rear-Wheel Drive
4.9L 145 hp I6
4-Speed Automatic Overdrive 15 / 20 mpg
4-Speed Manual Overdrive 15 / 20 mpg
5-Speed Manual Overdrive 15 / 20 mpg
4.9L 145 hp I6
Horsepower 145
Torque (lb-ft) 265
Valves/Valve Configuration No data
Displacement (cc) 4917
Bore X Stroke (in.) 4.00 X 3.98
Compression Ratio 8.8:1
Fuel Type/System No data/MPFI
http://repository.carsite.com/index.cfm?page=4&INVENTORY_ID=1224142 shows:
Base Number of Cylinders: 6
Horsepower: 145 hp
Max Horsepower: 3400 rpm Torque: 265 ft-lbs.
Max Torque: 2000 rpm Maximum Towing Capacity: 7500.00 lbs.
Drive Type: RWD Turning Circle: 44.50 ft.
Old May 4, 2008 | 11:03 AM
nismokid's Avatar
The New Jessie James
It might work. It should. Its a ford!
