Tail light issues: GMC S15
Old Mar 11, 2008 | 12:12 AM
SmokinS13SR20's Avatar
That ginger...
Default Tail light issues: GMC S15
The truck is an '83 with an Auto.
It is also the 'High Sierra' version.
With the lights on I have no tail lights. When I turn on a turn signal (either direction) both tail lights blink.
When I picked up the truck, none of the lights worked at all. Awhile ago I went to the junkyard and grabbed a male and female connector that mounts right onto the rear of the bumper and wired it back in. There was a hacked job of wiring done to wire in trailer lights. Well, it's wired back to the way it should be per the haynes manual, and it's the same damn thing.
Could a bad relay or something of the sorts cause this issue?
Old Mar 11, 2008 | 07:59 AM
Clint's Avatar
keyboard hardass
do the front blinkers flash both at the same time as well as the rear, or do the fronts work correctly?
Old Mar 12, 2008 | 08:26 PM
That ginger...
The fronts work perfectly fine.
