Problems!!
Old May 19, 2007 | 02:01 PM
Pimpgixxer04's Avatar
Default Problems!!
Hey guys whats goin on, i got a couple questions...well i have a 93 jeep cherokee and i was driving it about a week ago and i noticed that the clutch felt very easy to push in and then i barely have to let it out to start to move whereas before i had to let it out pretty far to go....and also after i realized it was doin this i decided to change the transmission oil and i drained it and the transmission had tons of metal shavings and i was wondering what could be wrong but then i was gonna fill the transmission with oil again and i CANT GET THE DRAIN PLUG off cause its so damn stripped..do u know of any way i can get it off? oh and do u know what size the fill plug is?? i couldnt figure it out.. thanks
IF IT HAS TITS OR TIRES YOUR GONNA HAVE PROBLEMS
Old May 20, 2007 | 05:03 PM
anyone please!
Old May 20, 2007 | 07:07 PM
jta's Avatar
jta
high five joel sucks!!!!!
Can fill it through the shifter? Just a thought.
Old May 21, 2007 | 06:39 PM
what do u mean? the shifter?
Old May 21, 2007 | 06:51 PM
jta's Avatar
jta
You can't fill it because you can't get the fill plug out right? If the shifter is mounted directly to the trans then you can remove it and fill it with fluid through the hole the shifter goes in.
Old Jun 26, 2007 | 04:20 PM
kegaration's Avatar
weld a bolt head or bar to it and turn it wile its hot
Old Jun 28, 2007 | 09:38 AM
BareLy UgLy's Avatar
Sgt. BA Baracus
why would you turn it while it's hot? not sure what type of weld you're doing but if the drain plug is also hot, won't turn.
|¯¯l,[___],
l---L--[]llllll[]¬
()_) ()_)--<>-)_)
GO BRUINS
BEAT SuC
Old Aug 29, 2007 | 12:38 PM
kegaration's Avatar
have you done this ? i have, do you weld ? i do,
do you want it out so you can put a new one in ?
or do you want to pussy foot around with it
Old Aug 29, 2007 | 12:42 PM
kegaration's Avatar
i know this is an old thread old but for some reason i may not like you BareLy UgLy
Old Aug 29, 2007 | 05:27 PM
Sgt. BA Baracus
aw did i hurt your ego??
get the fuck over it.
|¯¯l,[___],
l---L--[]llllll[]¬
()_) ()_)--<>-)_)
GO BRUINS
BEAT SuC
