chevy 6.0L wont start??
Old Apr 11, 2006 | 07:51 PM
SUPER DUBER D-MAX's Avatar
Default chevy 6.0L wont start??
ok well i thought it was this and that i got a whole new ignition switch the hole deal... ok i turn on the key its cranks up then shuts right back off..
idk what it is changed the fuel filter and everything... i mean what is the missing link because im ready to go to lakeland mud bogs and shit thing wont run...
how much fuel pressure should i be makeing???
plz help me
thanks
tyler
Old Apr 12, 2006 | 05:24 PM
JM's Customs's Avatar
try performancetrucks.net it might help you out more and what year truck
Dont hate cuz it looks getto
2000 ECSB Silverado, 5.3 V8
Performance: K&N FIPK, PowerAid TB spacer, TB bypass, Cold Fusion 150 shot wet kit. smokn' competition and transmissions
Appearance: Cervinis bumper cover, Xenon body kit, Goodmark ram air cowl hood, shaved tailgate, roll pan, halo & projector headlights, clear lights, DBL-G 10, NT420s 295/30/22
Old Apr 13, 2006 | 09:50 AM
BigTruckinMF85's Avatar
"POLK COUNTY"
did you check the altinater???
You have the right to remain silent...
anything you say or do will be misquoted
and then used against you.....
Old Apr 15, 2006 | 01:42 AM
1stGen7's Avatar
layin frame for life
LOL mike he said it starts then shuts off... means altanator is good if it rolls over
sub stage. 4 american bass XD 15's
sub amps. 2 audiopipe APSM1500's
mid's. 16 american bass SQ 6.5's 8 pyle pro super tweets
mid's amps. 2 autotek ATX3000.2 and 1 autotek ATX950.4 on the tweets
Old Apr 26, 2006 | 06:37 PM
keith455's Avatar
TR Balla Donor Supreme
I have no idea what year truck you have but did you pull the codes from it? assuming that it has an ECU
Keith F.A.S.T. Riverview FL
'06 MazdaSpeed6
'91 GMC Syclone #2173 '92 GMC Typhoon #1191
'04 GMC Sierra 2500SLE CC/SB Quadrasteer
'75 Oldsmobile Hurst/Olds
'84 Hurst/Olds '86 Pontiac 2+2
'53 Buick Super
'95 Seadoo XP '97 Seadoo SPX
http://www.syty.net
http://www.riverviewforums.com
Old Apr 29, 2006 | 01:44 PM
BlackWind's Avatar
Requiem
try some ether.if it stays running while using ether, its ur fuel.
did you push the rotor down all the way?
are you getting adequate spark?
plus it may very well be ur fuel pressure regulator,dirty injectors/jets,or a bad fuel pump.check the amperage going to and from ur fuel pump and check all relays and fuses.
Old May 6, 2006 | 04:13 PM
Southern_SS's Avatar
maybe pcm needs to be relearned.
turn key to on position leave it for about 15 min. makes sure lights,radio,ac,etc are all turned off.
after 15 min turn key to off position then try to start.
sometimes takes a couple of tries. i had to do this 3 times when i repro my pcm.
Old May 8, 2006 | 06:10 PM
BlackWind's Avatar
Requiem
normally the pcm (when it needs to be relearned will still allow the truck to run, but it will run like a fat ass on crack with a broken leg... and thats bad.
Old May 8, 2006 | 08:53 PM
hideinginfl's Avatar
Is moveing on up
or you have a factory theft system, and some how your key becane unprogramed. which is probabley what it is if it starting and stopping. i work for dodge and thats what are cars will do
Rip Kevin "Slo-si" Gonzalez 9-13-06
