Alpha Pit in Ocala CLOSED!
Originally Posted by Amortized
heard a kid died out there 5 months ago after wrecking his atv, if its true, we've seen the end of alpha.
2003 Ford F350 FX4 6.0L - White/2007 Front Clip
16" Custom Lift/Dual Resivour shocks/Traction Bars
42x15R20 Swamper SX2's/20x12 black XD Rockstars
Road Armor Stealth front-rear Bumpers/AMP Powersteps
Recon Smoked LED everything/Smoked LED 1 pc Headlights
ARP headstuds/EGR Delete/SCT Xcal3 Custom Tuned/RCD 190cc injectors/Some other stuff
Originally Posted by Brian3000gt
there are pits in pedro florida also they just reopened .just for some info
88 mustang hatch
holley 650dp carb,175 shot nos,3g alt,underdrive pulleys,strut tower brace,tko trans,bbk x-pipe,2 chamb. flows,jet coated shortys,urethane mounts,tri-ax shifter,moroso 7 qt pan,msd wires,sumped fuel tank,twin holley blue pumps,alum.driveshaft,axle brace,billet bearing caps,tru-trac diff,fms gears,solid pinion spacer,moser axles,smog pump delete,msd 6al,cobra brakes,roller thrust plate,f cam,stealth intake,ported track heat heads,lots of other crap i cant remember.
88 mustang hatch
Originally Posted by White93YJ
i can guarentee it'll be reopened within 3 months.
still closed.
http://www.tampaforums.com/forums/in...g-you-off.html
How to keep a mortgage broker from ripping you off!
CWB
CWB
