MR2 clutch problem
Old Sep 21, 2010 | 01:27 PM
i_always_get_some's Avatar
Default MR2 clutch problem
I had my clutch, clutch slave, master, and flywheel changed at the end of June. They, coincidentally, were all bad, so they were replaced by a certified mechanic. My clutch pedal has not felt "right" since, maybe, two weeks after getting the work done. It just didn't feel as tight and crisp. I figured the parts were broken in, so I sorta ignored it. I decided to bleed the clutch thinking there might be a little air in the lines. Now there is NO pedal pressure. The pedal comes back, it has no resistance. I used a self bleeder, then called someone over to help bleed, thinking that the bleeder was leaking air. There has been no improvement. I took it to Toyota and they think it's my slave. i'll know tomorrow. Has anyone ever heard of a slave going out that fast? 2 in one year sound very unusual. I'm thinking something else must be causing it to fail. It's a Perfection from Advance Auto Parts.
91 MR2 5spd N/A 97K
Old Sep 22, 2010 | 09:16 AM
hachibill's Avatar
yea sweet lemonade
i've gottan a bad slave before, just take it back to where u got it and they will give u a new one
Old Sep 22, 2010 | 09:57 AM
williamb82's Avatar
grease monkey!
its prolly a rebuilt unit. when i replaced my master and slave in my 84, i got them from napa. that was like 5+ years ago. still working perfect.
http://www.cardomain.com/ride/2042690/1 black 84 supra, 7mgte, truetrac, bbk, etc.. more in the works
http://www.cardomain.com/ride/2117186/1 blue 85 supra, beater
http://www.cardomain.com/ride/2965297/1black 86. saved from the crusher! wicked setup on the way.
http://www.cardomain.com/ride/2235741/1 64 chevy c10, finally getting a new body. woot!
Old Sep 24, 2010 | 12:40 PM
MR Dizzle's Avatar
That's right bitches !!
Nothing is wrong with your slave... trust me!! once you let the pressure out of the clutch line, its a real PITA to get pressure back. go to sears, buy a mityvac speed bleeder for around $40 bucks and that will solve your issue.
The way toyota designed this system is very flawed. Sometimes while bleeding it, air bubbles can get trapped by where the slave bolts to the tranny. i usually use the mityvac to vacuum out the whole system, then crack one of the hard lines loose till all of the air hisses out. This job takes a while, i would take it to a mechanic if you're not up for it. best of luck!!!
Old Sep 25, 2010 | 04:27 PM
Mr.Dizzle was right. Damn air stuck near slave. Cost me $100 to bleed at Toyota. Took them FOREVER, though. At least I didn't have to worry about it. Thanks guys.
