Wtb Mk4 Parts
Old Jun 21, 2009 | 04:40 PM
LexusKrazzyBoy's Avatar
Default Wtb Mk4 Parts
hey guys blew my 7mgte so im goin 2jz-NA-T anywho i need some parts i need a tt head gasket, tt pistons, tt injectors and a NA-T manifold for the turbo. also i need new or used AEM UEGO. please need the supra up and running again
Old Jun 22, 2009 | 01:52 AM
kbprice's Avatar
Rocket Scientist
Rather than swapping pistons just get a thicker, 2.5mm, headgasket. It'll lower your compression ratio plenty and save all the hassle of tearing the block apart. Don't use TT injectors unless you have the resistor pack for them. You can get 550cc RX7 high impedance injectors that will drop in without any modifications. Just some recommendations from someone who's been there.
'96 Supra NA-T
"I'm not driving fast, I'm flying low..."
Old Jun 22, 2009 | 08:32 AM
Boosterseat's Avatar
No Rice Here
You do realize your car will be down for about 3-4 months regardless, possibly more. There is a lot of custom work that is needed, and be prepared to spend around 10k. Also from what I read you want to do a 2jz N/A swap, then turbo it? why?
Old Jun 22, 2009 | 11:56 AM
Because it cheap and well I have someone who will do the swap for 1200 so I'm good and were can I get the 2.5 head gasket from and how much also were do I get the rx7 550s at and thanks for the info
Old Jun 23, 2009 | 01:51 AM
kbprice's Avatar
Rocket Scientist
RX-7 Injectors FS over on Supraforums. Boostlogic.com has the headgasket and any other related NA-T parts you may need.
'96 Supra NA-T
