20v oil cooler???
Old Dec 7, 2007 | 09:19 PM
kantfadedisazn's Avatar
The Asian Pimp Daddy
Default 20v oil cooler???
ok on the refferance page this is what it states "AE86's "reserve pressure" oil cooler block should be removed as it's pressure retention spring can drop the oil pressure. Use and aftermarket "positive feed" oil block and larger aftermarket oil cooler for best results. VVT thrives on the high oil pressure to move quickly in and out of position so never do anything to drop the pressure in the 20V."
so my question is can i use the factory gts oil cooler with an aftermarket sandwich plate?????
vien at Adventperformance.com
Old Dec 8, 2007 | 03:51 AM
B18C5-EG's Avatar
A sandwitch plate will not drop your oil pressure. But dont get some 10$ sandwitch plate either. Why do you want a new sandwitch plate neways?
Old Dec 8, 2007 | 08:13 AM
becuase the 20v cannot run the stock oil cooler so i have to get the sandwich plate to be able to run the oil cooler, but people on club4ag are telling me it wont work if i want to run a full flow type only bypass type so im confused
Old Dec 9, 2007 | 01:53 PM
Orion ZyGarian's Avatar
7M 2JZ bird in pear tree
Forget that. A water-to-oil cooler is what you want.
ASE: Brakes
