Are Lowering Clamps Safe ?????
Old Nov 16, 2007 | 07:52 AM
Phantom Zero's Avatar
Hail the 7th generation
Post Are Lowering Clamps Safe ?????
I wanna drop a few inches but im saving for a turbo kit so im kinda on a budget, is clamping down your lowering springs with those things they sell at autozone ok or a no no ????
Old Nov 16, 2007 | 07:58 AM
HellofaPrzeFghtr's Avatar
The One and Only
lolz
Old Nov 16, 2007 | 08:59 AM
2kSnakeater's Avatar
Pastafarian FOR LIFE!!!!!
Do it, and dont forget to post from the hospital if you do it wrong and shoot a spring thru your car's fender.
sig under construction
Old Nov 17, 2007 | 08:06 AM
RTA Supra's Avatar
RIP Kevin
If you can afford to turbocharge your 03 Celica, you can afford to spend the 250 for a set of Eibachs. It's hard to believe you're turbo'ing your car after asking about lowering clamps
Looking for OEM Acura parts? PM me
GO BOLTS!
09 Civic Si
Old Nov 17, 2007 | 12:59 PM
Lightbulb Ohhh ok then
Well i heard ud spend well over 250 to get a good suspension kit,
with that in mind every dollar counts.
but 250 i guess is not bad at all , thanx for informing me.
and yeah springs shooting out the fender , fuck that .
good point.
Old Nov 18, 2007 | 07:07 AM
RTA Supra's Avatar
RIP Kevin
Coilovers cost over 250, yes
GO BOLTS!
09 Civic Si
Old Nov 19, 2007 | 08:00 AM
thus my point
Old Nov 26, 2007 | 10:17 PM
hombredelassrtas's Avatar
S/C'ed C/F Connoisseur
yea 250 isnt getting a good suspension. It will get you a set of springs but not shocks. and other then TRD or the equivalent eibachs (same spring different label) which are .8", you will need shocks to compensate for the drop. So if your that strapped get a set of eibach pro's (i think are the . and put them on your stock springs. it will be noticable but cheap, i think around 150 on ebay)
Other big issue is there is not enough clearence room for the celica to use spring clamps. if you look up in the wheel well the sping itself goes higher up in a tight space. this would in most cases not fit the clamp. Since i have had the celica i have never known anyone to have spring clamps on a 7th gen, or atleast none that admit it
MP62 Supercharged
"Who Needs Moral Fiber When You Have Carbon Fiber"
