7th gen celica headlights
Old Mar 14, 2007 | 12:12 PM
HollyRenee's Avatar
Holly Renee
Default 7th gen celica headlights
hey! i hope someone can help me.. but i'm trying to remove the covers of my headlights so that i can clean them. Does anyone know how i can do that? let me know! thanks
*~Holly Renee ~*
Old Mar 14, 2007 | 03:49 PM
lowredcruzr's Avatar
Automotive Progression
yeah but you prob dont need to remove them call me and i'll walk you through doing it
justin
813 716 9025
00 toyo celica gt-st
04 Ford F-250
96 ek hatch
Old Mar 14, 2007 | 07:33 PM
Phillycheese917's Avatar
Usually the inside of your headlights dont get dirty it is basically a closed system. It maybe the outside of the lights. Try using Maguires plastx on the outside. It clearsup plastic really well. If you do want to take them apart, this might sound crazy but it is basically the easiest way, you will want to heat up your oven to 300* then turn it off when it is at 300 degrees. (THIS IS IMPORTANT BECAUSE YOU DON'T WANT TO COOK YOUR HEADLIGHTS) Put them inside for about 10-15 min. Then take them out and pry them apart from sides. You might have to reheat several time before getting them apart. If you take them apart you should paint the housing. If you have any questions private message me.
