jz transmission interchange
Old Oct 1, 2006 | 07:40 PM
86Supraguy's Avatar
Default jz transmission interchange
i managed to get my hands on a 2jzge but i need to know if the auto bellhouseing is interchangeable with the r154 trans or what MANUAL trans will fit if any. Suggestions are welcome.
Old Oct 2, 2006 | 10:35 AM
psifactor's Avatar
Hello
The answer to your question is no.
an auto bell housing will not bolt up to a r154. If you want to use an r154 with the 2jz you will need a manual 1jz bell housing and I think that will bolt right up to the 2jz block. Now clearance and other issues I have no idea.
Heavy car with a 2.5L
Old Oct 3, 2006 | 07:46 PM
agentAndy's Avatar
more class than college
yea you need to either use a 1jz bellhousing, r154, 1jz flywheel, and a 7m turbo clutch kit, OR a mk4 na flywheel, or is300, or sc300 5speed flywheel, and a mk4 na, sc300 or is300 5speed.
no auto bellhousing will interchange with a manual box.
Andrew Carroll @ XAT RACING
team v8 in the works. hold one tango.....
hot hot heat in the cup!!!
Old Oct 4, 2006 | 08:31 AM
86Supraguy's Avatar
thanks. i wasnt to shure about that. but dose that mean i cant use a mk4 tt trans?
Old Oct 4, 2006 | 09:27 AM
kbprice's Avatar
Rocket Scientist
You can use the MKIV TT manual tranny if you can find one. They will cost more than your looking to spend I believe. Used 6 speeds are running $3000+ in good condition, $2500 if they need rebuilding - which will run you about $1000.
'96 Supra NA-T
"I'm not driving fast, I'm flying low..."
Old Oct 4, 2006 | 01:16 PM
86Supraguy's Avatar
yeah that is a little much. ill just skick with r154.
Old Oct 5, 2006 | 09:49 AM
kbprice's Avatar
Rocket Scientist
W58's will also bolt right up. That is the NA MKIV 5 speed. I've seen them going for $300 on Supraforums.
'96 Supra NA-T
Old Oct 5, 2006 | 04:44 PM
86Supraguy's Avatar
really i allready got one in my surpa now. i might just use that then. but what about the clutch????? will i still use the 2jz one or what???
by the way nice cars kbprice.
Old Oct 6, 2006 | 03:57 AM
kbprice's Avatar
Rocket Scientist
The W58 came standard in MKIV NA Supras. They are the same dimention as the ones in the MKIII Supra. All the clutches for MKIII and MKIV NA are the same, so yes you can use the same clutch and flywheel you have.
Thanks for the props.
'96 Supra NA-T
