FS: RHD JZA70 stuffs... before it goes to the shredder
Old Oct 28, 2004 | 04:13 PM
flubyux2's Avatar
Elitist Supra Asshole :)
Default FS: RHD JZA70 stuffs... before it goes to the shredder
Ive got the left-over halfcut from the 1JZ swap, still have everything left to make your car RHD... the clip didnt come with little things like center consol trim and what nots. have pedals, steering column, dash board (composite support is broken but still fits right), lower kick panels (i think), glove box (i think)...
but if someone has a project they want to convert to RHD to be Madd JDM Tyte, you better come get this shit before i throw it away... cuz the scrap yard pays for steel and aluminum.
seriously, someone make a RHD car from this and take my clip...
Old Oct 28, 2004 | 06:42 PM
cassio's Avatar
Vendor/Advertiser
have the mud flaps and any other exterior stuff hit me up on IM usfbull1981
thanks,
-ian
sold>> Single gt3582r powered 2jzgte
Ellis Autoworkz
Smoke 2004 LE
Crew Cab *Big Tow Package *4x2
Old Oct 28, 2004 | 11:51 PM
agentAndy's Avatar
more class than college
how about the firewall badge?????
Andrew Carroll @ XAT RACING
team v8 in the works. hold one tango.....
hot hot heat in the cup!!!
Old Oct 29, 2004 | 06:07 PM
flubyux2's Avatar
no, the firewall badge was missing when we got it... stupid cubans with fake jamaican accents...
Ian... ive got the Driver side mud flap, the driverside fender trim w/ the Euro marker lens and the driverside rear tail light moulding that has half of a "Limited" badge still stuck to it... thats all i really had as far as trim. the passengerside mud flap was bent and torn so i ddidnt think youd want it.
i removed EVERY thing from the clip, even the firewall, so someone can take all this and physically make a RHD supra.... right down to the hood release cable and trunk/gas door release levers.
i ended up cutting the car down the middle to fit it in the U-haul pickup. ill get some pics.
heres what the "kit" includes;
89+ subframe with round mounts and anti-sway bar attached
Steering rack
Fire wall with bolt holes and flanges for accelerator, brake, clutch, steering column, dead pedal, etc.
Power brake assy with master cyl, booster, pedal, linkage, vacc pipe with 1-way check valve and light switch
Heater core vacuum valve w/ VSV
Accelerator pedal
Speedo cable
Wiper motor with wiper linkages and pivots
Various junction blocks if you so choose to keep all the electrical stuffs
Dashboard cross-brace (big metal bar)
Dashboard (gray) with center console brackets (mounts to driveshaft tunnel)
Dash wiring harness (cut in several places, i will try to put it back together)
Hood latch and bracket with release cable
Trunk and gas door release levers and bracket
Steering column with turn signal stalk, wiper stalk and ignition key (you keep your steering wheel)
Lower trim piece with Dimmer rheostat, sunroof switch and something else
dont have;
glove box or liner; it was broken when i got it
center console/HVAC/STereo trim piece
Stereo
HVAC controls
HVAC center vents
Heater core/box and ducting
AC core/box and ducting
Under-dash panel to cover steering column
i know someone could make use of this... i would do it but the supras i have right now are too cherry to mess up, plus one is going up for sale as soon as its done. ive got other priorities before i can build a RHD car... i was wanting to do it to an 86.5 Hard top Sport and gut the rest of it... make it a bad ass Drift car... but, again, i gotta build 2 7M's first, and install those brake lines, completely redo the brakes on both DSM's, and look into ordering that Soarer from japan.
Old Oct 29, 2004 | 11:31 PM
agentAndy's Avatar
well at least i got my badge
Old Oct 30, 2004 | 10:13 AM
psifactor's Avatar
Hello
here is what happends to bad cars.
Heavy car with a 2.5L
