T3 quality
Old Jun 19, 2004 | 08:38 PM
Kirby's Avatar
Default T3 quality
Ive heard that T3 suspension products for AE86 break often and are not of good quality? Just curious if anyone has had any experience with thier coilovers because im thinking of getting suspension soon for the hachi.
Old Jun 19, 2004 | 09:38 PM
aphxero's Avatar
"the apex hero"
I have T3 lateral rod, hub spacer, and roll center adjusters. I'm very happy with the quality. I plan on buying their camber plates asap.
As far as the coilovers go. They are custom so you can use any shock/spring rate you want as long as it's short stroke. Most people do HTS or AGX. you could buy the sleeves and cut/weld the strut casing on your own for alot less $$$.
Have fun
Part of:
Wangan Midnight Maximum Tune 2 sedan expert.
APXRO: JZX100 Chaser "Odaiba Romance" 815HP/DG B1 2 overhauls. secret weapon
PM!: UCF10 Celsior "Jealousy" 810HP/DG B3 0 overhauls. vs battle car
Old Jun 19, 2004 | 10:39 PM
Kirby's Avatar
Ive considered welding and cutting the sleeves myself but Ground Control only makes their coilover sleeves in aluminum, and as far as I know Steel and aluminum dont weld to well. So my only choice would be to weld a collar for the sleeve to sit on and that sounds like a pain to to do. Also how do the AGX and HTS compare to each other is it worth the extra $$ for the HTS? The cheapest ive found HTS were like 539$ with out shipping while the AGX are 359$ shipped.
Old Jun 19, 2004 | 11:26 PM
n2ocamry's Avatar
FUCKCAMRY HELLOHACHI
i have the
rca's
lateral rod
front strut tower bar
short throw shifter
and im very satisfied
whenever the shits get dirty a scotch brite pad cleans them right up also
i also have the agx shocks all around also (with trd japan springs)
i love mine
nuff said
2 thumbs up
