fabricate
Old Jun 2, 2004 | 07:25 PM
toyotajoe1980's Avatar
drifting in the rain
Default fabricate
Iwill be getting a mr2 engine for my hachi and want to put bigger injectors in it is it true i can use supra injectors out of a 88 supra turbo also need lsd can i use the one from the same supra i have some other ideas but those will come out in time
SOLDfor sale::::ae86 sr5 converted to twin cam carburated
webers/ headers/ msd/ 4puck unsprung clutch/ 10000rpm tach
4 point harness/ custom exhaust/ custom camsSOLD
Old Jun 3, 2004 | 08:57 AM
æ86's Avatar
i have herad of people using supra rear ends but im not sure whats involved, im not sure about the supra injectors i think i remember peaople doin it but im not really sure. i know 250cc injectors from a celica gts with 3sge are used by some hachi guys
Old Jun 4, 2004 | 07:54 PM
found a spray kit for one time use 30 shots that i wanna put on the intake man.
also going to machine the head for better comp. ratio
more to follow
Old Jun 5, 2004 | 05:35 PM
3 way valve job
port and polish head
custom intake man.
"Hooker" headers
CAI
mass air mod.
4 msd coil packs running to accel 300+ wires and iridium 4 NGK plugs
high comp ceramic pistons
2.5" custom no cat. exhaust
not to mention...
the supra injectors and lsd
or the head machined
and the spray for the custom intake man.
but that is mostly a pipe dream
I guess I will have to see what I can afford
Old Jun 5, 2004 | 08:16 PM
riddlemr2's Avatar
2 seats > 4
Default Re: fabricate
Well, you can use the 550's out of a mkIV, but switching to mkIII injectors would be useless. The mr2 tranny is not in any way similar to that of a mkIII tranny, so no, probablly not. Use the LSD out of the '94+ JDM mr2 tranny.
-Dave
Join www.clubmr2.com
'91 MR2...12.32@112
Old Jun 6, 2004 | 02:49 AM
Orion ZyGarian's Avatar
7M 2JZ bird in pear tree
Anybody with a Mk3 and still has the 7M-GTE in it over 350HP has 550cc injectors and Lexus AFM. It would be worth it though to swap the turbo manual Mk3 tranny (R-154) into the AE86 if it fit, its an incredible tranny.
ASE: Brakes
